But it needed help.
It started up and run pretty well after a few cranks to get the fuel going.
For about 45 seconds. Then it quit. It turns over but doesn’t fire.
Its getting fuel.
There’s 12.5-ish volts at the coil. Battery is new last year and spent the winter on a charger/maintainer and tested very strong this morning.
I suspect the Pertronix ignition system.
I have the old points still, but I wasn’t prepared to swap them at the storage facility.
I think that’ll be the first thing I try, but not today. I’ve had enough.
Any other thoughts and guidance is welcome.
Oh, yeah. Is it normal to see a puff of smoke come out of the negative battery cable when you’re cranking the engine?
It happens right where the cable and the terminal end meet.
It‘s an old cable. Probably original. I’ve been shopping for a replacement for a few years now. I guess it’s time to bite the bullet and just get what I can get instead of worrying about ‘correct’.
Its getting fuel.
