Chrysler to use Atkinson engines?
Chrysler will use an Atkinson-cycle V6 on its newminivans, according to reliable source oh2o.
The normal minivan willuse a standard Pentastar engine, while plug-in hybrids will have an Atkinson-cycle version with an SI-EVT (SingleInput Electrical Variable Transmission).
Mazda uses the Atkinson cycle in its SkyActive cars and Toyota uses it for the new V6 in the Tacoma.Thiswouldbe the first Atkinson version of the Pentastar V6. Allpar’s “AutoTechnican” wrote,
Generally, for the Atkinson cycle, you raise the static compression (e.g. to 13-14:1), and hold the intake valves open into compression stroke. This effectively makes the power stroke longer than the compression stroke, allowing more energy to be extracted.
More...
