Car stereo deck help please?
Fishy
Omnipotent Seaweasel
Ok I seem to remember someon eelse having a deck they need info on and got it. Hoping the same hold true for me:helpme:
Really all I wanna know is how to program the stations and set the time. Everything else I was able to figure out by tinkering with it for a bit.
Don't know what to look for modelwise so I'll just give you guys the info of the detachable faceplate.
Pioneer. EEQ Mosfet 50wx4 Super TunerIII D
Other than button functions that's all I get from the face. Thanks for any and all help guys!!! [smilie=::
There should be a model number SOMEWHERE on the faceplate. Or is it possible to take a picture and post it on here?
Ok I felt kinda lazy for not wanting to go and look on the unit but it did me no good. No #'s anywhere!:wtf: How odd...:hmmm:
DEH-1600 I'm assuming from the picture address. And Pioneer requires a username and password to get to the user manual :doubt: But I have ways around that:
Presets:
When you find a frequency that you want to store in memory, press a preset tuning button 1-6 and hold until the preset number stops flashing.
BSM (best stations memory) lets you automatically store the six strongest broadcast frequencies under preset tuning buttons 1-6 and once stored there you can tune in to those frequences with the touch of a button.
Press LOCAL/BSM and hold until the BSM turns on. BSM begins to flash. While BSM is flashing, the six strongest broadcast frequencies will be stored under preset tuning buttons 1-6 in order of their signal strength. When finished, BSM stops flashing.
To cancel the storage process, press LOCAL/BSM.
Clock:
Press SOURCE and hold until the unit turns off.
Press AUDIO and hold until clock appears in the display.
Press < or > to select the segment of the clock display you wish to set. Pressing < or > will select one segment of the clock display: Hour - minute. As you select segments of the clock display, the segment selected will blink.
Press up or down button to set the clock. Pressing up will increase the selected hour or minute. Pressing down will decrease the selected hour or minute. To cancel clock settings, press BAND. You can also cancel clock settings by holding down AUDIO until the unit turns off.
Just under the lower left corner of the display. Pretty tiny print:
Or if Pioneer doesn't allow linking pictures:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3442/49927837DEH-1600_big.jpg
Thanks MM! Will give it a go tomorrow. And damnit if I didn't look very carefully for a model # EVERYwhere on this thing. Now I see it:doh: Mine says DEH-16.
Looks exactly the same only in red instead of green.
Presets:
Clock:
They should make em blink like the vcrs of old, let's everyone know.
