Proform Racing Series, (no choke baffle), Vacuum Secondary,
Available in either 650 or 750 cfm. New retail $525 - $585. Very desirable race carb. Although some idiots try to run them on the street.:doh: The Proforms are basically an upgraded Holley. Some common defects improved. Also, the Proform cfm ratings tend to be a little under-rated. That 650 may be in actuality more like 700cfm.
To tell which size this is check the throttle bore sizes. If there's a slight difference, it's a 650. If all 4 are the same size it's a 750.
