71ChargerRT
So as many of you know I now have a pair of '69 Valiants.
The first one I bought is going to be a street car, my low compression 1972 440 is going in there, once I get it running correctly I'm going to do a cam swap and a few other odds and ends to get it a little peppier. I am pulling the too wide D44 and swapping in a 59-1/2 8.8 Ford rear with offset shackles and hangers so I can run a 15X7 wheel with a 245/60-15 on the rear and a 215/65-15 up front. I've been collecting parts and I have almost everything I need to get it together, goes back into the garage this weekend.
Valiant 2, or the Nova as Doc nicknamed it, is actually a little bit nicer of a car even though it spent close to 25 years in a junkyard. The floors are shot, and there is a small spot of rust behind the drivers rear tire, rusted from the inside out. I am thinking about mini tubs and grafting in Duster or 2nd gen Barracuda wheel openings so I can get a bigger tire under there. I want to cage this one and make it a ridiculously quick street/strip car with a turbo'd low deck stroker.
