Answers every question I never had.
It does answer the question "does this old wive's tale help or hurt?" "No"
BTW you don't need a mic to see the pin offset. There's no way to miss it.
I never really cared for DF. He comes across as a guy who just finished learning what he's about to explain to you. I know that's not true, that's just how it seems to me on TV.
The piston's not upside down. In the photo I looked at you could only see the arrow on one and it was upside down. I started cleaning and checking, and it turns out the passenger side always looks upside down. I checked them all to be sure they're all turned the right way anyway.
Also, from the HAMB "That damage isn’t usually caused by something getting in the bore. Thats an oil, mixture, ring, overheat, bearing play issue thats caused the piston scuff, I’d want to find the cause. You don’t want it to happen again."
The block's a mess, as far as being clean goes, but I got most of both decks cleaned up too.
I may put this one back together and send the other +.030 440 block I have to the machine shop.
I think if I could buy a 440 crate engine for the cost of a BPE 360 I'd consider just buying one and get it over with. I looked into that when I was thinking about a crate for our Duster and all I found were race strokers at about 2x the price of the BPE 360, and I decided the BPE was too expensive, so there.
