a pinion snubber question???
fourforty6pac
Does someone make a snubber that is a bolt on for a dana 60 that is not an original mopar 60? I found a nice dana 60 4.10 with 35 spline alloy axels. It does not have the provisions for the snubber, but it does fit under my 72 b body. The bolt pattern is 5 on 4 1/2. It looks like it has been used in a couple different cars because it looks like the perches were welded at least a couple of times. I would like to use this but there is no way Im putting traction bars on a mopar (I did that when I was a youngster, then I learned). Thanks.
Sounds like a re-axled truck '60'
No one makes a bolt-on snubber, that I know of.:huh:
I do recall someone posting pics of how they adapted a truck housing to bolt on an OEM snubber. It's a matter of using some chunks of metal the correct size, drilling & tapping and then welding to the housing.;)
What you have is a truck housing that someone cut to fit a car. To my knowledge, there is no way (easily) to instal a snubber.
