TheIronSausage
Two brain cells left.. rubbing together for warmth
So, an update on the barge.. I went out to the site today with the intention of freeing up some stuck calipers, and starting the motor. I pulled the distributor and primed the pump, turned the motor in between, yada yada.. Reinstall distributor, try and start.. Inevitable backfiring through carb, switch all wires 180 on cap, because I can never put the damned distributor back in the right way the first time. Try and start it again, fires right up and settles to an idle. After mosquito fogging four lanes of Rt 50 for ten minutes, tried a gear. Idle drops, car tries to move. I eventually get it out of the ruts it's sitting in, and the damned thing not only has a brake pedal, but the brakes work great.. They even fully release. So, throw all of my shit in the New Yorker, and drive it ten miles home. It sits in traffic and doesn't overheat, the tires don't feel flat spotted until you hit seventy.. All the gauges work, it's even got a half a tank of gas that doesn't smell like total varnish that it runs well on. I'm definitely going through the brakes and fuel system, but this is a win. Nobody's done any maintenance to this thing in at least seven years, and I doubt it's seen forty miles in that time. Certainly hasn't been moved in two or three.. I'm the proud owner of more ugly junk that even brand devotees (including myself) didn't even want.
