2015 Jeep Wrangler
2015 Jeep Wrangler - $29,999 - Anaheim, CA - INSTALLED FEATURES: Rear vents: second row, Airbag deactivation: passenger switch, Front airbags: dual, Side airbags: front, Antenna type: mast, Auxiliary audio input: USB, In-Dash CD: single disc, Radio data system, Radio: AM/FM, Total speakers: 6, ABS: 4-wheel, Electronic brakeforce distribution, Front brake type: disc, Power brakes, Rear brake type: disc, Cargo area floor mat, Floor mat material: carpet, Floor material: carpet, Floor mats: front, Shift knob trim: urethane, Steering wheel trim: urethane, Ambient lighting, Assist handle: front, Center console: front console with storage, Cruise control, Cupholders: front, Power outlet(s): 12V front, Power steering, Power windows: lockout button, Reading lights: front, Retained accessory power, Steering wheel mounted controls: audio, Steering wheel: tilt, Storage: door pockets, Vanity mirrors: dual, Liftgate window: fixed, Rear door type: side-hinged, 4WD type: part time, Axle ratio: 3.21, Transfer case: manual hi-lo gear selection, Alternator: 140 amps, Battery rating: 600 CCA, Battery: maintenance-free, Cargo tie downs, Door handle color: black, Front bumper color: black, Grille color: black, Mirror color: black, Rear bumper color: black, Skid plate(s), Tow hooks: front, Window trim: black, Clock, Compass, Digital odometer, External temperature display, Fuel economy display: MPG, Gauge: tachometer, Trip odometer, Warnings and reminders: lamp failure low fuel engine oil coolant, Daytime running lights, Front fog lights, Headlights: halogen, Taillights: LED, Side mirror adjustments: manual folding, Removable roof: soft top, Active head restraints: dual front, Body side reinforcements, Child seat anchors: LATCH system, Crumple zones: front, Impact sensor: post-collision safety system, Front seatbelts: 3-point, Rear seatbelts: 3-point, Seatbelt force limiters: front, Seatbelt pretensioners: front, Seatbelt warning sensor: front, Driver seat manual adjustments: height, Front headrests: adjustable, Front seat type: bucket, Passenger seat manual adjustments: height, Rear headrests: adjustable, Rear seat folding, Rear seat manual adjustments: reclining, Rear seat type: bench, Upholstery: cloth, 2-stage unlocking doors, Hill descent control, Hill holder control, Roll stability control, Stability control, Traction control, Front shock type: gas, Front spring type: coil, Front stabilizer bar, Front suspension classification: solid axle, Front suspension type: multi-link, Rear shock type: gas, Rear spring type: coil, Rear stabilizer bar, Rear suspension classification: solid live axle, Rear suspension type: trailing arms, Spare tire mount location: outside, Spare tire size: full-size, Spare wheel type: steel, Tire Pressure Monitoring System, Tire type: all terrain, Wheels: aluminum, Front wipers: variable intermittent, Tinted glass: front driver and passenger
Link to ad on Hemmings.com
