Pros: The 2014 Audi S5 Coupe stands out with a lowered and tightened suspension (featuring an available sport rear differential that can actively distribute power laterally across the rear axle for even more balanced handling), sexy and discreetly aggressive looks, standard all-wheel drive, a powerful V6 that's commendably fuel-efficient, as well as a rich combination of luxury, refinement, and technology.
Cons: Once again, the MMI controls will not prove user-friendly to all drivers. The back seat, even for a coupe, is pretty tight.
[TD="class: caption"]Photo: Audi[/TD]
2014 Audi S5 Coupe Price: As was the case last year, the lineup includes two trim levels -- Progressiv and Technik. The first one starts at $55,900, and the second retails from $60,700.
2014 Audi S5 Coupe Fuel Economy: Expect to burn 13.1L/100km in the city and 8.3L/100km on the highway with the manual transmission. These numbers drop to 11.7L/100km and 7.7L/100km, respectively, when opting for the dual-clutch autobox.
Improvements and Changes: The newly available Audi Drive Select helps you customize individual vehicle components at the push of a button and thus alter the dynamics of the car. Other changes are in the areas of enhancements to packages and standard-equipment lists.
Powertrain: The 2014 Audi S5 Coupe accelerates from 0-100 km/h in a mere 5.1 seconds thanks to a 3.0L supercharged TFSI V6 engine with direct injection that channels its 333 horsepower and 325 lb-ft of torque through a standard 6-speed manual gearbox or the available 7-speed S tronic dual-clutch transmission. As mentioned earlier, power is distributed to all four wheels by way of Audi's acclaimed quattro system.
Cargo Capacity: The S5 Coupe boasts a 346-litre trunk.
Safety: Six standard airbags keep 2014 Audi S5 Coupe occupants protected from the front and sides, while stability control helps secure the trajectory at all times. In the event of a collision, intelligent sensors automatically unlock the doors, switch on interior and hazard lights, and cut off fuel flow to the engine. Adaptive cruise control and a rear parking system are available.
Comparing the 2014 Audi S5 Coupe: The BMW 435i xDrive, Cadillac ATS Coupe V6 (2015) and CTS Coupe, Lexus RC (2015), Infiniti Q60 Coupe, and Mercedes-Benz C 350 4MATIC are all strong competitors of the S5.
More...
More...
