Pros: With its signature soft top, which opens in a mere 15 seconds and takes just two seconds longer to close, the 2014 Audi S5 Cabriolet brings open-air freedom to the heightened performance of the S5. The three-layered design of the acoustic roof gives it outstanding noise and heat insulation properties. This convertible also stands out with a lowered and tightened suspension, sexy and discreetly aggressive looks, standard all-wheel drive, a powerful V6 that's commendably fuel-efficient, as well as a rich combination of luxury, refinement, and technology.
Cons: Once again, the MMI controls will not prove user-friendly to all drivers. The back seat is pretty tight, and the coupe's manual gearbox is nowhere to be found in the cabriolet.
[TD="class: caption"]Photo: Audi[/TD]
2014 Audi S5 Cabriolet Price: As was the case last year, the lineup includes two trim levels -- Progressiv and Technik. The first one starts at $68,800, and the second retails from $74,100.
2014 Audi S5 Cabriolet Fuel Economy: Expect to burn 11.8L/100km in the city and 8.0L/100km on the highway with the S5 Cabriolet.
Improvements and Changes: The newly available Audi Drive Select helps you customize individual vehicle components at the push of a button and thus alter the dynamics of the car. Other changes are in the areas of enhancements to packages and standard-equipment lists.
Powertrain: The 2014 Audi S5 Cabriolet accelerates from 0-100 km/h in 5.5 seconds thanks to a 3.0L supercharged TFSI V6 engine with direct injection that channels its 333 horsepower and 325 lb-ft of torque through a 7-speed S tronic dual-clutch transmission. As mentioned earlier, power is distributed to all four wheels by way of Audi's acclaimed quattro system.
Cargo Capacity: When the top is stowed away, it has little effect on the trunk thanks to its intelligent Z-fold design. That means you get 288 of the S5 Coupe's 346 litres of cargo room.
Safety: Front and side airbags keep 2014 Audi S5 Cabriolet occupants protected, while stability control helps secure the trajectory at all times. In the event of a collision, intelligent sensors automatically unlock the doors, switch on interior and hazard lights, and cut off fuel flow to the engine. Adaptive cruise control and a rear parking system are available.
Comparing the 2014 Audi S5 Cabriolet: The BMW 435i xDrive Cabriolet, Lexus IS 350 C, and Infiniti Q60 Convertible all compete against the S5 Cabriolet.
More...
More...
