2008 Dodge Sprinter
2008 Dodge Sprinter - $22,900 - Evansville, IN - 2008 Dodge 2500 170" WB 5-door High Top Sprinter cargo van (VIN: WD0PE845385308192), arctic white ext. with grey fabric seats, 188,050 miles, 5-spd. auto trans, extended 170" wheel base with 5 doors, 3/4 ton chassis, high top version with solid panel sliding door on passenger side, rear barn doors with no windows, seats two, 3.0L 24V DOHC V6 Mercedes-Benz common rail turbo diesel engine (154 hp. / 280 lb-ft. torque), alloy block, electronic fuel injection, rack and pinion power steering, independent front suspension with leaf springs and shock absorbers, solid live rear axle suspension parabolic leaf springs and shock absorbers, 4-wheel disc brakes with ABS and brake assist, stability and traction control, adaptive electronic stability program with electronic roll mitigation, electronic brake force distribution, roll movement intervention sensor, power windows and door locks, 2-keys and remotes, cruise control, tire pressure monitors, cold A/C, adjustable steering wheel, Adrian steel divider with opening door between cargo / driver area, lighted cargo area, rear step and trailer hitch with electronic trailer brake controller installed. Rear is completely open with some Jemrack open bunk type storage shelves. Drives extremely well and everything works as designed. Just detailed and is in exceptionally nice condition inside and out - if you stood next to this Sprinter and I told you it had 40,000 miles you wouldn't doubt it, tires are very recent front and rear. Most owners report fuel mileage anywhere from 21-25 mpg., 25.0 gallon fuel capacity. With diesel prices at $4.00 / gal. think of the savings over a regular box truck or cargo van. 1 owner since new with a clean AutoCheck report and the new 3.0L motor and updated body and interior. Approx. $44,000.00 new MSRP. Under 10,000 GVWR so you don't need a CDL to drive it. These are rare and very difficult to find, ESP in this condition! US built in Pooler, GA. Offered for quick sale at $22,900.00 / best offer. Call or text Brian @ (812) 760-5513 or www.BuxtonMotorsports.com
Length: 273.2", Box / cargo length: 162", Width: 79.7", Box / cargo width (wheel): 53.1", Box / cargo width (wall): 70.1", Height: 107.5", Box / cargo height: 77.5", Wheelbase: 170.3", Ground clearance: 6.9", Interior cargo capacity: 494 cubic feet, Max towing: 5,000 pounds, Max payload: 3,301 pounds, Gross weight: 8,550 pounds, Curb weight: 5,267 pounds
Link to ad on Hemmings.com
