2008 Dodge Sprinter
2008 Dodge Sprinter - $17,950 - Evansville, IN - 2008 Dodge 2500SHC 144"wb Low Top Sprinter van (VIN: WD0PE745885296647), arctic white ext. with grey fabric seats, 154,700 miles, 5-spd. auto trans, short 144" wheel base with 5 doors, 3/4 ton chassis, low top version with sliding passenger side mid door, windowless rear barn doors, seats two, 3.0L DOHC V6 Mercedes-Benz common rail turbo diesel engine (154hp. & 280 lb-ft. torque), electronic fuel injection, rack & pinion power steering, independent front suspension with solid live rear axle suspension, 4-wheel disc brakes with ABS, stability & traction control with electronic brake force distribution, tilt steering wheel, Options incl: power windows / door locks / ext. mirrors, cruise control, keyless entry (1 key and 1 remote) and cold A/C, cargo area with D-ring tie downs in floor, tire pressure monitors. Rear is completely open with no storage racks etc. Drives great and everything works. Most owners report fuel mileage anywhere from 21-25 mpg. city and 25-28 highway, 26.4 gallon fuel capacity. With diesel prices at $4.00 / gal. think of the savings over a regular box truck or cargo van. Under 10,000 GVWR so you don't need a CDL to drive it. These are rare and very difficult to find! US built in Pooler, GA. Offered for quick sale at $17,950.00 / best offer. Call or text Brian @ (812) 760-5513 - located in Indianapolis, IN.
Length: 273.2"
Width: 79.7"
Height: 107.5"
Wheelbase: 144.3"
Ground clearance: 7.4"
Cargo length: 128.5"
Cargo width wall to wall: 70.1"
Cargo width between wheel wells: 53.1"
Interior cargo capacity: 141.3 cubic feet
Max towing: 5,000 pounds
Max payload: 3,074 pounds
Gross weight: 8,550 pounds
Curb weight: 5,613 pounds
Link to ad on Hemmings.com
