2007 Jeep Wrangler - $79,000 - Albuquerque, NM - This is the baddest jeep in the united states. I have over $125,000 invested. This jeep is a show stopper. When out driving it everyone looks. You feel like a celebrity. Every show I've put this jeep in I have taken first place including the 2012 Miami beach week best of show 2012. You will not find another jeep this bad. Here is what it has. IT'S A 2007 Jeep Wrangler Sahara Call of Duty Black Ops Edition Rock Crawler
List of Modifications
IT'S TRULY A ONE OF A KIND JEEP
JEEP WANGLER SAHARA PROFESSIONALLY BUILT
AND UPGRADED WITH EACH AND EVERY OPTION
ON OR OFFROAD VEHICLE
VEHICLE HAS A 3-PIECE MOPAR MODULAR ROMOVABLE HARD TOP WITH FULL STEEL DOORS, ELECTRIC WINDOWS AND LOCKS
ROCK HARD FULL ROLL CAGE FRONT AND REAR
2 MAX OUT 1LB CHROME FIRE EXTINGUISHERS MOUNTED ON DRAKE OFF MOUNT
CUSTOM MADE BUILT 10 1/2 INCHES LIFT WITH LONG ARM FULLY ADJUSTABLE SUSPENSION
18 INCH ARTICULATIONS IN THE FRONT TRAVEL AND 16 INCHES IN THE REAR
FOX RACING 18 INCH TRAVEL SHOCKS WITH REMOTE RESERVIOR AND TRIPLE EIBACH COILS PER SHOCK,
FIVE SUPPER SWAMPERS IROX
42X14 R17 TIRES
MOUNTED ON FIVE K17 DIAMO WHEELS
(17X10 WITH 8X6.5 BOLT PATTERN)
DANA 60 KINGPIN FRONT DIFFERENTIAL AXLE WITH ARB AIR OPERATED LOCKER
5.38 RING AND PINION SETUP AND (Yukon) 35 SPLINE INNER AND OUTER SHAFTS AND 35 SPLINE WAREN MANUAL LOCKING HUBS
REAR DANA 60 WITH ARB AIR OPERATED LOCKER 5.38 RING AND PINION SETUP AND FULL FLOATING 35 SPLINE YUKON AXLE SHFTS AND MASSIVE 13 INCHES ROTORS AND ALL WILLWOOD CALIPERS IN FRONT WITH INTERNAL SELF ADJUSTING E-BRAKE IN BACK
POISON SPYDER ROCKER KNOCKERS (3/16 STEEL SIDE ARMOR) AND FRONT AND REAR POSION SPYDER CRUSHER STEEL FLARES MADE OUT WITH 1 ¾ X .120 DOM TUBING AND 3/16 STEEL WITH REINFORCEMENTS
1330 CV TYPE TOM WOODS FRONT AND REAR DRIVESHAFTS
2 DOUBLE STEERING FOX DAMPER SHOCKS
DUAL OPTIMA YELLOW TOP DEEP CYCLE BATTERIES MOUNTED UPSIDE DOWN IN THE REAR
BTF HIGH STEER
KILBY ENTERPRISES ENGINE DRIVEN AIR COMPRESSED SYSTEM WITH 2.5 GALLON TANK- FILTER AND FRONTAND REAR BUMPER OUTLETS WITH 100 (PSI) AND VACUUM
(FUEL ECONOMY)
CUSTOM MADE ELECTRICAL SYSTEM THAT BROUGHT ALL THE ELECTRICAL PARTS INSIDE THE VEHICLE GLOBE BOX KEEPING COMPUTER, RELAYS, FUSES AND MOTHER BOARDS AWAY FROM THE EXTERNAL ELEMENTS LIKE WATER, DIRT AND INCLUDE A FIREWALL INSTALLED PERKO SHUT OFF MASTER SWITCH
FRONT WARN 9.5 TI THERMOMETRIC ELECTRIC WINCH MOUNTED ON A CUSTOM MADE STINGER TYPE FRONT BAR WITH 4 IPF 900XS AUXILIARY LIGHTS ( TWO DRIVING BEAM AND TWO SPOT TYPE) 50" LIGHT BAR, 4 RUGGED RIDGE LED LIGHT AND AN AIR COMPRESSED OUTLET
REAR 9.5XP 6.5HP WARN WINCH MOUNTER ON A CUSTOM MADE REAR BUMPER WITH TIRE CARRIER HOLDING A MATCHING 42 INCH TIRE AND WHEEL
HI LIFT JACK
2 INCH TOW RECEIVER WITH AN AIR COMPRESSED
OUTLET TO FILL UP TIRES OR WORK WITH AIR TOOLS
3 TRAIN HORN
4 GREEN ORACLE PLASMA HALO EYES ( Head lights and Blinkers)
NEW KC HEAD LIGHTS
ORACLE LED LIGHT STRIPS UNDER THE BODY TO LIGHT UP THE NIGHT
ORACLE LED LIGHT STRIPS IN THE CAB
SUPERCHIPS PERFORMANCE CHIP WITH CUSTOM TRAIL DASH DISPLAY
PROFESSIONALLY POWDER COATED ABQ MANUFACTURING
CUSTOM INTERIOR WON BEST OF SHOW INTERIOR
EVERY BUSHING, TIE ROD END, BEARING FRONT AND REAR HAS BEEN REPLACED THIS YEAR
VEHICLE HAS OVER $125,000 INVESTED
ONLY ASKING $79,000 Save you over $45,000 from doing it your self.
SERIOUS BUYERS ONLY 505-480-33THIRTY
Link to ad on Hemmings.com
