moparnut
Administrator
2007 Dodge Sprinter - $21,500 - Evansville, IN - 2007 Dodge 2500 170" Long wheelbase 5-door High Top Sprinter van (VIN: WD0PE845175193588), arctic white ext. with grey fabric seats, 130,470 miles, 5-spd. auto trans, extended 170" long wheel base with 5 doors, 3/4 ton chassis, high top version with solid panel sliding door on passenger side, rear barn doors with no windows, seats two, 3.0L 24V DOHC V6 Mercedes-Benz common rail turbo diesel engine (154 hp. / 280 lb-ft. torque), alloy block, electronic fuel injection, rack and pinion power steering, independent front suspension with leaf springs and shock absorbers, solid live rear axle suspension parabolic leaf springs and shock absorbers, 4-wheel disc brakes with ABS and brake assist, stability and traction control, adaptive electronic stability program with electronic roll mitigation, electronic brake force distribution, roll movement intervention sensor, Options: power windows / door locks / mirrors, cold a/c, keyless entry with 1 key and 1 remote, cruise control, tire pressure monitors, solid divider with locking door between cargo / driver area. Rear walls are finished and both sides have metal shelving and drawers (removable). E-track and D-rings in the cargo area floor, rear step. Drives extremely well and everything works as designed. Just inspected & serviced at the local Sprinter dealer and is in very nice condition inside and out - if you stood next to this Sprinter and I told you it had 40,000 miles you wouldn't doubt it, Firestone tires are approx. 40-50% front and rear. Most owners report fuel mileage anywhere from 21-25 mpg. in the city and higher highway, 25.0 gallon fuel capacity. With diesel prices at $4.20 / gal. think of the savings over a regular box truck or cargo van. Books, manuals and window sticker. 1 owner since new with a clean AutoCheck report - 2007 is first year for the the new 3.0L motor and updated interior and body. $38,940.00 new MSRP, options shown on the photos of the window sticker. Under 10,000 GVWR so you don't need a CDL to drive it. These are rare and very difficult to find, ESP with this mileage and in this condition! US built in Pooler, GA. Offered for quick sale at $21,500.00 / best offer. Call or text Brian @ (812) 760-5513 or www.BuxtonMotorsports.comLength: 273.2", Box / cargo length: 163.5", Width: 79.7", Box / cargo width (wheel): 53.1", Box / cargo width (wall): 70.1", Height: 107.5", Box / cargo height: 78", Wheelbase: 170.3", Ground clearance: 6.9", Interior cargo capacity: 494 cubic feet, Max towing: 5,000 pounds, Max payload: 3,301 pounds, Gross weight: 8,550 pounds, Curb weight: 5,267 pounds
Link to ad on Hemmings.com
