2006 Dodge Sprinter
2006 Dodge Sprinter - $16,500 - Evansville, IN - 2006 Dodge 3500 158" LWB 5-door High Top Sprinter van (VIN: wd0pd544x65902655), arctic white ext. with grey fabric seats, 171,000 miles, 5-spd. auto trans, extended 158" wheel base with 5 doors, 1-ton chassis, high top version with solid panel sliding door on passenger side, rear barn doors with windows, seats two, 2.7L DOHC V6 Mercedes-Benz common rail 5-cyl. turbo diesel engine (154hp. / 243 lb-ft. torque), alloy block, electronic fuel injection, rack and pinion power steering, independent front suspension with leaf springs and shock absorbers, solid live rear axle suspension parabolic leaf springs and shock absorbers, 4-wheel disc brakes with ABS and brake assist, stability and traction control, adaptive electronic stability program with electronic roll mitigation, electronic brake force distribution, roll movement intervention sensor, Options: power windows / door locks / ext. mirrors, cruise control, cold standard A/C, lots of parts bins and storage (removable), wired for air compressor to work with a power inverter (not included) and has about 50' of air hose on a reel as well as an underbody mounted air tank, stainless steel folding work bench, tow package, newer tires & all cabinets etc. are completely removable for cargo use. Drives extremely well and everything works as designed. Most owners report fuel mileage anywhere from 18-22 mpg., 26.4 gallon fuel capacity. With diesel prices close to $4.00 / gal. think of the savings over a regular box truck or cargo van. gvwr 9990. Offered for quick sale at $16,500.00 / best offer. Located in Indianpolis, IN. Call or text Brian @ (812) 760-5513 or www.BuxtonMotorsports.com
Link to ad on Hemmings.com
