1972 T&C/full sized Mopar wagon parts
71ChargerRT
I'm looking for a fuel tank, 1969-1973 should be all the same.
Drivers front door, I believe that's a '72/3 specific part 4 door and wagon.
Power window motor rebuild kits, do they exist?
There's more, I'll just have to locate my list and update.
I've got a fuel tank for a 73 Newport sedan.. Do the wagons still have goofy 12 gallon side mounted gas tanks in the seventies? I know the sixties did..
Yeah, the tank is wagon specific and mounts in the 1/4 panel. 2 door/4 door tanks are available new.
that door wont just pop out?
as for the motors..rip them apart..measure up the brushes..spin the com on a drillpress with 500 grit paper...10-1 odds are new brushes can be ordered..thats all there is to rebuilding ANY small electric motor
You may not see it in the pic, but there's a crease. I'm no body man, by any stretch, so I figure I'll just swap it out. That's not critical, or even necessary at this point, but I threw it in in case someone had one lying around that they might get rid of cheaply.
I'll yank the motors and take them apart, I didn't know if there was something specific that needed to be done.
Odds are pretty good everything in the window regulator assembly is just trying to work through old, stiff grease and not-so-soft track seals. Brushes won't hurt but cleaning and re-lubing might be all that's needed in the short term.
yup....those old motors rarely die...and i had tested them ...not to full extent just enuf to see if they moved and they did so yeah..probably just a dissasemble clean lube and reasseumble...i just like to do brushes and com while im in them
