1970 Plymouth Cuda
1970 Plymouth Cuda - $51,900 - Manchester, NH - This rotisserie restored 1970 Plymouth Cuda 340 was completed in 2010. According to the previous owner, the car came from Wisconsin. Prior to that, the car was Titled in Alabama. This documented 340 Cuda has a #'s matching 340 engine. The car was built July 20th, 1970 in Hamtramck MI. Given new life, this beautifully restored example has undergone a complete restoration from front to back. Options are: E55 340-4V engine, D32 HD Torque Flite trans., EV2 Hemi Orange/Tor Red Irid., full vinyl roof, bucket seats, console, hood tie down pins, sport hood, road lamps, roof drip rail moldings, wide sill moldings, belt moldings, quarter panel tape treatment "hockey stripe", dual chrome dual tip extensions, am radio, 26" radiator 14" Rally wheels that have been upgraded to P215/70R 14" BF Goodrich radials. The body and paint was professionally restored to the quality standards as you can see. It has a straight body with no waves or apologies in the exteriors finish. 2 stage base coat clear coat paint system gives the car that smooth glasslike look. Beautiful body lines, highly detailed through out the entire car. Countless hours of body prep went into blocking and wet sanding to achieve such a fantastic show quality finish. Every nut, bolt and screw has been replaced or refurbished on this Cuda. The stainless, bright work, chrome, trim and emblems are in excellent condition through out. Most of these cars look better now because of the better quality paint products that produce that high gloss finish than when they were manufactured. In the collector car world...we call it "jewelry", for an award winning fit and finish. The under carriage is as nice as the top. OEM parts were used for the most part on this highly detailed engine compartment that wins hands down at the car shows. This rare example was very expensive to restore. The vinyl top has polished restored stainless, new wheel opening moldings, color keyed dual sport mirrors with driver's side remote, restored grille, lower rocker moldings, nice original glass, except replacement windshield, restored door handles, restored grille, grille surround moldings, tail light lenses and surround moldings are in super nice condition. New radio antenna, working am radio master with dual rear speakers, key buzzer, beautifully restored dash pad by "Just Dashes", restored instruments, new seat covers, carpet, door panels, headliner, rear pkg. tray, orig. wood style steering wheel with no cracks, non-Rally dash car, factory seat belts. Checking out the engine compartment, you'll notice that fresh factory appearance right down to the correct Mopar tar top reproduction battery. The motor was over hauled and was rebuilt to stock factory specs, #'s matching 340 engine, factory intake, new Edelbrock 600 CFM card with electronic choke. Electronic ignition, orig. 26" radiator, factory exhaust manifolds with the OEM dual exhaust system, dual resonators with the chrome tip extensions, new engine bay wire harness, new headlight harness, proper ground straps, orig. style hoses and clamps, new washer bottles, orig. air cleaner element with dual snorkel, high quality paint wet sanded and buffed in the fender apron and fire wall areas along with the underside of the sport hood. The correct overspray on the front of the radiator support with the Vin # on the back of the support and on the top off the cowl. New brake lines, new PS pump, rebuilt steering box. Every fastener is in place, date coded spark plug wires, new front nose and fender hardware wit hood bumpers, hood insulation, new o=hood pins and cowl hood weather strip. Brilliant front grille with no cracks, road lamps work fine. Show quality triple plated chrome bumpers with that mirror like shine. The underside is OMG! Correct dated but not original 727 Torque Flite automatic was rebuilt during the restoration. New shift bushings, complete new front end components, K-Y B shocks, fuel lines, brake lines, new hardware, new gas tank, sending unit springs, ball joints, tie rod ends, center link, drums, brake hardware, e-brake system, sway bar link all appear new. The wheel opening areas are refinished in the EV2 paint. Inner fender aprons, wheel house areas, al the correct splash shields with all the hardware. Spotless on the under carriage. Looking in the trunk, it is restored in the same high quality paint. Orig. spare tire, jack and trunk mat with spare tire cover and complete new trunk wire harness. This 70 Cuda is considered a #1 condition car that has been only driven sparingly since the restoration. Comes with Broadcast sheet and fender tag. One work describes this E-body Mopar...STUNNING! Check it out! Up to 120 months financing with approved credit. Newer trades welcome.
Link to ad on Hemmings.com
Yes, from the slipped spring glamp to the missing quarter drains to the obvious, still-present rust damage painted over at the rear bumper bulkhead, "OMG" is certainly a useful term... just not in the manner you think.
These cars just don't bring that kind of money right now. The "jizz in my pants, it's an E-body!" phase is over, kids.
