1970 Plymouth Barracuda - Inquire - Milford, CT - 1970 PLYMOUTH "CUDA" 440/375 H.P.(U CODE) 4/SPEED-TRACK PAK BUILDSHEET YEAR: 1970 MAKE: PLYMOUTH MODEL: CUDA 440 BODY: COUPE COLOR: JAMAICA BLUE TRIM: BLACK ENGINE: 440/375 H.P.4BBL TRANS: 4/SPEED REAR: 3.54 SURE GRIP MILES: 51,010 EXEMPT SERIAL#: BS23UOB166306 FACTORY OPTIONS(FROM FENDER TAG) AO1 - LIGHT PACKAGE A33 - TRACK PAK A62 - RALLYE GAUGES B51 - POWER BRAKES C16 - WOODGRAIN CONSOLE C55 - BUCKET SEATS G33 - LH REMOTE MIRROR J45 - HOOD PINS L31 - FENDER MOUNTED TURN SIGNALS M21 - DRIP RAIL MOULDING M25 - BODY SILL MOULDING M31 - BODY BELY MOULDING M88 - REAR DECK MOULDING N41 - DUAL EXHAUST N42 - CHROME EXHAUST TIPS N85 - TACHOMETER R11 - RADIO W21 - RALLY WHEELS Y05 - USA ORDER 26 - 26" RADIATOR SERIAL# BREAKDOWNBS23UOB166306 BS - PLYMOUTH CUDA 23 - 2DR HARDTOP U - 440/375HPV8 0 - 1970 B - HAMTRAMCK PLANT 166306-SEQUENCE # ENGINE/TRANS(MATCHING NUMBER) BLOCK# 2536430 - 6 - 440/375H.P V8 1-4BBL DATE CODE: 11-11-69 TRANS: 677 A833 SERIAL# - 166306 REAR: 3432079 DOCUMENTATION * ORIGINAL BUILDSHEET * GALEN GOVIER REGISTRY (#38 OF 102) * GOVIER FENDER TAG BREADOWN * GOVIER BUILDSHEET BREAKDOWN RESTORATION A COMPLETE BODY AND MECHANICAL RESTORATION. EVERYTHING DONE PROFESSIONALY RARETY 9520 - 1970 440 4BBL PLYMOUTH CUDAS BUILT 334 - WITH 4/SPEEDS EB7 - JAMIACA BLUE COLOR VERY LOW PRODUCTION MATCHING # AS YOU CAN SEE THE CAR WAS SCHEDULED PRODUCTION DATE(SPD) OCT 23 1969 AND THE MOTOR DATE IS 11-11-69. BASED ON RESEARCH 1970 CARS BUILT AT HAMTRAMCK (SPD) WERE BUILT WITHIN 3 WEEKS OF ACTUAL (SPD). SO THAT MEANS THE CUDA AND ENGINE DATES ARE WITHIN THE 3 WEEK PERIOD. PLEASE CALL LENNY @ (203) 668-7797 FOR MORE INFO!!! WILL CONSIDER INTERESTING TRADESLink to ad on Hemmings.com
