1970 Dodge Charger - Inquire - Wichita Falls, TX - Lone Star Muscle Cars Is Proud To Present This True Icon Of American Muscle A 1970 Dodge Charger R/T Recreation. Born As a 500 Model With A 318 Motor Has Been Upgraded To A Mopar Performance 472 Street Hemi Block This 472 will produce An estimated 550 H.P. Here Are The Internals A (Cummins Cast), 4.250 Bore finish honed with deck plates, Deck, Pan Rail, and bell housing surfaces squared and trued, Line Honed Cleavite Cam bearings, S/S frost and oil galley plugs, 4.150 stroke Eagle 4340 Chrome Molly forged 6 bolt crank-shaft micro polished and computer balanced, Eagle H Beam Connecting Rods 4340 forged with ARP rod bolts computer balanced, Pistons forged 10.5 to 1 compression ratio computer balanced, Childs and Albert file fit performance molly rings, Oil pump millings high volume standard pressure 7 Quart oil pan with ½ inch pick-up tube, 7.250 harmonic balancer, Comp Cams: Cam Shaft hydraulic .503 valve lift, Comp Cams hydraulic performance lifters, Mellings silent high performance timing chain, Cylinder heads: Mopar performance cast iron street hemi W/SS valves, Mopar Performance adjustable roller/rocker arm assembly's Mopar Performance hydraulics 3/8 hardened push rods, Mopar Performance black wrinkle valve covers, Mopar Performance timing chain cover, Holley Performer Carb, Mopar Performance aluminum water pump assembly. Hi performance MSD electronic ignition kit, Mopar performance M1 single four barrel intake manifold, Optional Equipment added: Conversion Motor mount kit. Aluminum Heads. All This Power Is Put Thru A Super Strong Automatic Transmission To The 8 3/4 Sure-Grip Rear End With The Ratio Of 3:55 For Those Who Like To Take Off Real Fast. Also Under The Hood You Will Find A Custom A/C System From Classic Auto Air A Very Hard Thing To Find On A Hemi Car. Power Steering A Custom Power Disc Brake System Was Also Installed With A Hydro Stat Brake Booster. On The Inside You Will Find All The Classic Interior Has Been redone And Freshened Up With The Floor Shifter And The Rally Gauge And Tach With Bucket Seats. On The Outside You A Show Quality Bright Red Paint With The Black Vinyl Top With New Wheels And Tires. Call Today For More Info!!! And Ask About Our Classic Car Financing Program.Link to ad on Hemmings.com
