1969 Dodge Super Bee
1969 Dodge Super Bee - $54,900 - Manchester, NH - The Mopar that dominated the streets, this Superbee was built and intended for one thing..."drag racing." Restored in 2000 by a retired teacher from northern Maine who has a passion for Mopars, restored this rare example from the ground up, while maintaining it's factory appearance with no modifications, has only been driven approx. 800 miles since. Driven to local car shows, this, Superbee has won 1st place trophies every where it went. Production of these factory built race cars were only 1,487, 826 w/4spd., 661 were automatic. Rebuilt correct date coded 440 engine, not orig. engine, however cast 2536480-8 dated Nov. 3, 1968. 906 high compression cast iron cylinder heads, correct Edelbrock alum intake with 3 two barrel Holley carbs, factory style exhaust manifolds with OEM style dual mufflers with the correct chrome tip extension. Dual point distributor, date code spark plug wires, correct Mopar belts & hoses with orig. style clamps, restored orig. radiator part #2949054, correct 6 pack radiator shroud, fan and clutch. The car is equipped wit PS, manual drum brakes, restored 3 spd. wipers, other orig. items are: very expensive orig. metal 6 pack air cleaner element with orig. style air filter. Correct idle solenoid, Mopar coil, washer bottle w/washer pump and squirter. The engine bay is nicely detailed, new engine bay wiring harness, solid inner fender aprons, firewall refinished in vibrant Red finish and just as nice as the exterior finish. The front radiator support has the correct blk over spray and the vin # appears on the section between the radiator. The exhaust manifolds could use some refinishing in the powder coat system. Original fender tag has some slight rust, but legible. A new reproduction tag is also included with the car. Reproduction Six Pack hood that fits great. Metal hood props, hood pin tie downs riveted to the hood plates that are not scratched or worn. The over all appearance of the engine compartment is very good, only needs minor detailing to bring it to show quality. Complete overhaul of the engine, while the car was being restored. The exterior body and paint has countless hours of labor comprised to achieve the straight body and exceptionally nice paint with no flaws noticed. Restored bright work and stainless, polished and looks fantastic. White vinyl Bumble bee tail stripe. Doors that open and close with ease. High attention to detail in the door, trunk and fender jamb areas. Complete new weather strip kit, window felts, quarter vent rubbers, excellent chrome on the vent windows, stainless roof drip rail, driver's side remote mirror, new wheel opening mouldings, orig. 15" H steel style wheels with Coker Classic red line P225/75 R15" radial tires. Original glass with the exception of replacement windshield. The bumpers are re chromed to show quality, restored orig. front grille, refinished turn signal lenses, orig. side marker lenses are in fantastic shape. GE head lamp bulbs, new door handles, door locks with new gaskets, keys work and lock both doors. The car has the correct style radio antenna, rear bumper guards, orig. tail light bezels and the chrome trim is in excellent shape. Looking in the trunk, the car has its original trunk pan with factory spot welds, full size H wheel spare tire, orig. jack, new reproduction trunk mat. The under side of the trunk has a beautifully restored appearance with new jacking instructions and crayon markings, G70x15 as the factory would have done. Restored trunk and striker with the correct finish. Looking at the interior of this A-12 Six pack car, you'll notice the car shows like a freshly restored car. New seat covers, door panels, carpet, headliner, dash pad, factory seat belts, arm rest pads and bases, new chrome, plastic chrome on the switches, restored quartz clock, am radio, factory tach, all the gauges work. Aftermarket single oil pressure gauge neatly installed under the dash. Custom embroidered Super bee floor mats, restored shoulder belts, new sill plates and glove box liner, restored ash tray with working cigarette lighter, brake and e-brake pedals, the steering wheel is an original 3 spoke sport imitation wood steering wheel that has been repaired in one area, yet has 2 small cracks in the wheel. New rear pkg. tray. The interior is very comfortable and is in A-1 condition. Colum shift automatic with 6 passenger seating for the entire family! Checking out the underside of this Mopar...it has a factory or dealer installed undercoating that is hard as a rock! Appears to have all its original floor pans, with one tiny repair by the gas pedal right where your heel would rest, but looks great. All new front end components, shocks, brake and fuel lines, reconditioned orig. gas tank, completely overhauled brake system, e-brake cables etc. Ball joints, tie rod ends, center link, sway bars bushings are all new. Only word describes this A-12 Six Pack..."awesome!" Comes with an orig. Broadcast sheet, orig. fender tag with new reproduction fender tag. Documented one of 661 automatic A-12 cars built. Priced below market value.
Link to ad on Hemmings.com
Very nice for an older restoration, and an almost civilized asking price. :cool:
Their asking price is based on the length of the description. Luckily they stopped when they did. :D
