1969 Dodge Dart - $29,900 - Whiteland, IN - - Engine: 496 MOPAR Big Block 850 Plus HP
- Transmission: 727 Torqueflite Race Transmission
- Exterior Color: Yellow
- Interior Color: Black
496 MOPAR Big Block Engine
Forged Diamond Pistons 40 Over
Forged 4340 R.P.M L Beam Rods
Forged 4340 R.P.M Crankshaft Stroker Kit
Mahle Clevite 77 Bearings
Speed Pro Rings
All Been Balanced
A.R.P Main Bolts and Head
Main Caps Girdle
Double Roller Timing Chain
Comp Cam and Triple Valve Springs and Lifters
4130 Chromemoly Push Tubes and Keepers and Retainers
1 To 5 Harland Sharp Roller Rocker and Shafts
452 Heads Port and Polish with Harden Seats Stainless Valves
Heads Been CC and Bench Flowed
Melling High Flow Oil Pump
Edlelbrock Performer Match Ported Intake
850 Mighty Demon Carb
Aeromotive Fuel System 1000 Horse Power
Vortech Supercharger 6 Pounds of Boost with Water Injection
M.S.D 6-BTM Control 6000 R.P.M. Chip Can Go Higher If Needed 7200
Flex Plate Hughes and Pioneer Harmonic Balancer
727 TORQUEFLITE RACE TRANSMISSION
OH Kit
Teflon Stator Rings
Filter
Tf-3 Shift Kit
Reusable Pan Gasket
Sonnax Billet Servo
Direct Fric Red Alto
Solid Front Servo
Forward Red Alto
Brushing Kit
Kolene Stell Plates
Deep Pan
High Pressure Rigid Band
Filter Adapter
Kevlor Rear Band
Torque Converters TCI Super Street
Sonnax Band Strut
Fighter 3200 Stall
Bolt in Sprag
TCI Trans Cooler
Sonnax Spring and Rollers
Pinion Steel Planet
Pinion Rear Planet
Dana 60 Rear End
Narrowed 410 Gears with Track Lock
Heavy Duty Diff Cover
Disc Brake 78 Lincoln Continental
Moser Axles 3 Inch Studs
Heavy Duty Drive Line
TTI Headers with 3 Inch Exhaust
Flow Master 40 Series Mufflers
15 Gal Fuel Cell
3 Inch Min Tube
6 Point Roll Cage
Link to ad on Hemmings.com
