1968 Dodge Charger
1968 Dodge Charger - $89,900 - Plymouth, MI - 1968 Dodge Charger
VIN: XP29F8B303142
This '68 Charger was fully restored about 8 years ago and has approximately 5,000 miles on it. The previous owner kept it covered in a garage and only drove it on nice, dry days. If you've been searching for a true performance oriented '68 Charger with every upgrade desired in the MOPAR community, this is the one. Under the hood is a 440ci V8 engine paired to an A727 Torqueflite 3-speed automatic transmission.
Looking underneath you'll find a highly detailed frame and body, KONI shocks, which lowers this ride 1.5'' all around, newer bushings, straight pinch welds, solid rockers, original floor pans, and so much more.
The factory black interior is beautifully done as well. Bucket seats, floor shifter, center console, fresh carpeting, clean wood grain trim, clear gauges, and an aftermarket Recaro leather-wrapped steering wheel are just a few awesome features you'll find inside.
Check out over 100 HD photos and our in-depth video at vanguardmotorsales.com
Highlights:
- 440ci V8 Engine
- A727 Torqueflite 3-Speed Automatic Transmission
- Power Steering
- Power Brakes
- Front Independent Suspension
- Rear Leaf Spring Suspension
- Special Order Body VIN Tag
Mechanics:
440ci V8 Engine (#: 3698830-400)
- Casting Date: 10-27-1973
- Complete Edelbrock Top End Kit
- Compression Ratio: 9:1
The Previous Owner Claims the Following Engine Modifications:
- Edelbrock Performance Package:
- RPM Heads
- RPM Intake Cam
- RPM Lifters
- RPM Double Row Timing Chain
Quickfuel Single 4-Barrel Carb
- Mechanical Secondaries
- Dual Feed
- Electric Choke
A727 Torqueflite 3-Speed Automatic Transmission (#: 3410570L39160919)
- 3200 Stall Converter
Front Torsion Bar Suspension
- Bushings are In Great Shape
- Sway Bar
- New KONI Shocks
- New KONI Shocks
Dana 60 Rear End
- Ratio: 3.54:1
- Sure Grip
Brakes:
- Front POWER Disc
- Rear POWER Drum
- New Booster
- Upgraded Late Model Master Cylinder
- New Pads
- New Calipers
Exhaust:
- New Dual Exhaust w/ Dynomax Mufflers
- Aftermarket Edelbrock Performer RPM Aluminum Intake (#: 4T4405T4)
- Aftermarket TTI Headers
Key Components:
- POWER STEERING
- New Gas Tank
- Edelbrock Intake
- MSD Distributor
- MSD Wires
- MSD Blaster Coil
- MSD Box
- MSD Tachometer Adaptor
- New Alternator
- Big Aluminum Radiator
- Optima Red Top Battery
Cosmetics:
- Custom TIG Welded Valve Covers
- Bottom Side of Hood Is Nicely Painted
Body:
Deep Black Paint Finish w/ Silver Tail Stripe
Grille Is In Great Shape
Chrome Bumpers Are In Great Shape
Hood Fits Great w/ Fenders
Doors Fit Nicely w/ Body
Door Lips & Jambs Are Clean
Straight Body All Around
Vinyl Top Is In Great Shape
Inside Trunk Is Clean
- Floor Pans Are Solid
- Rubber Floor Mat
- Full Spare
- Deck Lid Is In Great Shape
Undercarriage Is Clean
- Original Trunk Floors Look Great
- Drop Downs Are Great
- Factory Undercoating
- Frame Corners Are Solid
- Rockers Are Solid
- Pinch Welds Look Great
- Original Floorboards Look Great
- K-Member Looks Great
Wheels: American Racing Chrome 18''
Front Tires: 245/45R18 – Nitto NT555
Rear Tires: 295/45ZR18 – Nitto NT555 Extreme ZR's
Interior:
Factory Appearing Black Interior Is In Great Shape
Bucket Seats
Floor Shifter
Center Console
Door Panels Are In Great Shape
Carpeting Looks New
Upholstery Is Clean
Headliner Is Clean & Tight
Dashboard & Dash Pad Is In Great Condition
Aftermarket Radio
Aftermarket Recaro Leather Wrapped Steering Wheel
Don't Miss Out! Call Tom 7 Days a Week at 248-974-9513!
tom@vanguardmotorsales.com
Link to ad on Hemmings.com
Previous owner claims the following engine modifications: Removed original 318, was unable to install musclecar VIN number or collector value associated with one.
A '68 Charger will always be a gorgeous collectible, but with an F VIN it's best to not attempt something like this as a venture from which one hopes to recover with any sort of solvency. Also, the wheels suck.
