1968 Dodge Charger - $189,900 - Charlotte, NC - SUMMARY480 cubic inch Hemi V8Tremec TKO600 5-speed manual transmissionCustom leather interior / Modern heat and air conditioning / Modern audioAir Ride Technologies adjustable shocks8.75-inch rear axle / 3.91 gearsAlterKtion front suspension / Articulated 4-link rear suspensionPower rack-and-pinion steering / Wilwood 4-wheel power disc brakesRushforth Rated-X wheelsDuPont Dodge Viper Snakeskin Green paintSale includes: an original broadcast sheet / An original Certicard / A copy of the car's 1968 titleIn the days of Hellcat Challengers and companies that engineer modern performance products for anything from a Civic to a Cadillac it's safe to say the Pro-touring movement is alive and well. And every so often we get a killer Pro-tourer that instantly draws a crowd even in our showroom of exclusive one-of-a-kind muscle cars. This vivid Dodge Charger which mixes 480 cubic inches of Hemi power with a proven Tremec 5-speed a thoroughly massaged suspension and custom leather upholstery has been drawing stares ever since it rolled in to our parking lot. And in fact between its outrageous aesthetics and chill-inducing stance the car has so much appeal that we've joked about keeping it around as a kryptonic display piece! But logic ultimately prevailed and we decided to offer it to you as an incredible classic that can be enjoyed both on the road and at the show.
BODYWORK/TRIM
After spending most of its life as a solid driver this clean coupe was the perfect starting point for a no-holds-barred rotisserie build that decked a hot Hemi big block in savage MoPar attitude. To kick things off the car's broad-shouldered Hamtramck body was stripped all the way down to bare metal. Once that metal was prepped and ready to spray DuPont Dodge Viper Snakeskin Green 2-stage was stacked on a virtually flawless profile. When that profile was completely sealed and fully buffed Flat Black war stripes were aligned with ''HEMI'' and ''480'' call-outs. And eventually this Dodge rolled onto the streets as a positively evil muscle car that tempers an old school no-nonsense demeanor with new age panache!
1968 was a notable year in American pop culture. The first Big Mac was served Elvis made a huge comeback and Dodge released what is probably the most iconic muscle car in its long history of performance. Sure you really can't go wrong driving any Charger. But when it comes to popularity few will argue the incredible significance of a '68 or '69-vintage B-Body. At the front of this coupe a black stainless-trimmed grille hangs a prominent ''Charger R/T'' script above a body-width bumper and green-detailed fratzog parking lamps. Above that grille a sculpted black-trimmed hood hangs small turn indicators in front of dark-tint glass that's set in spotless stainless frames. At the sides of that bonnet a faceted profile anchors chrome Chrysler door handles beneath traditional mirrors and a familiar 'pit stop' fuel filler. And at the back of that profile a black stainless-trimmed valance centers a bright ''R/T'' emblem between jet-inspired taillights and a second body-width bumper.
ENGINE
Hoist this Dodge's hood and you'll find 480 cubic inches of all-American bliss! Crossing big horsepower with neck-snapping torque that powerplant's revolutions begin with a polished ''HEMI'' branded air cleaner that's stretched over dual Carter 4-barrels. At the base of those carbs an aluminum Chrysler intake feeds cast iron heads which are dressed with requisite Organisol-coated valve covers. At the base of those heads TTI long-tube headers frame a beefy cast iron block. At the front of that block an MSD Pro-Billet distributor sequences fire between high quality Painless Wiring and clean Moroso Blue Max plug wires. At the front of those wires traditional V-belts spin modern power steering and a modern AC compressor at the side of an aluminum water pump. That pump circulates coolant through an oversized Wizard Cooling radiator that's mounted between a polished overflow and a snazzy custom-fabricated fan shroud. And aesthetically the Hemi Orange mill provides an excellent contrast to the car's smooth body-matched engine bay.
DRIVETRAIN/SUSPENSION
Toss this Charger on a lift and you'll find a Snakeskin Green undercarriage that's a product of professional grade customization and a roster of top-notch components. Behind the big block a slick Tremec TKO600 5-speed pairs a McLeod billet steel flywheel with a street performance clutch. That clutch engages a proven 8.75-inch rear axle that's fitted with big 3.91 gears. At the front of the car a familiar AlterKtion front-clip centers a beefy sway bar between adjustable Air Ride Technologies shocks. Opposite that clip a triangulated 4-link aligns two more Air Ride Technologies shocks behind welded subframe connectors. Modern power rack-and-pinion steering provides smooth turns and quick reflexes. Four Wilwood calipers utilize a Wilwood master cylinder and Hydratech hydroboost hydraulics to squeeze four drilled and slotted Wilwood rotors. Exhaust rolls from the aforementioned headers in to straight large-diameter pipes that are married to SPINTECH Performance mufflers. And at the corners of the chassis Satin Black Rushforth Rated-X spin 245/45ZR19 Hankook Ventus V12 EVOs in front of 255/45ZR20 Hankook Ventus V12 EVOs.
INTERIOR
Inside this awesome coupe a custom leather interior is clean well fitted and surprisingly simple. At the center of the cockpit a quartet of bucket seats centers tight snake-inspired hides under small rivets and a stylish green accent. In front of those thrones a custom green-trimmed dash hangs Classic Instruments All American telemetry beside Kenwood touchscreen audio and controls for the car's modern heat and air conditioning. At the bottom of that dash a custom full-length console founds a Hurst Pistol Grip Shifter on fresh carpet that frames billet foot pedals. At the edges of that carpet riveted side panels which mimic the outside of the car's doors seat pistol grip handles in front of modern power windows. Above those panels a leather headliner flows to a custom package tray. In front of the driver a Flaming River steering wheel laps a tilting Flaming River column. And behind the passengers a custom upholstered trunk does a great job of hiding the car's battery.
DOCUMENTATION
Despite its transformation into an all-out Pro-touring super star this Dodge enjoys quite a bit of historic provenance. Here's a short list of everything that's included with the car's sale.
An original Chrysler broadcast sheetThe car's original fender tagAn original Owner's ManualAn original Chrysler CerticardA copy of the car's 1968 titleA vintage registration card1977 AAMCO service records documenting a replacement transmissionA small stack of component manualsTwo Air Ride Technologies key fobsA Speedway Motors fuel gauge interface moduleBuilt for the most discerning muscle car fans on the planet this Charger is the perfect opportunity to bask in the spoils of owning a fresh world-class classic. The car looks absolutely predatory. And with a whole roster of top-notch equipment that's already spec-d and seamlessly bolted together it's your one-way ticket to instant gratification!
Link to ad on Hemmings.com
