1968 AMC AMX
1968 AMC AMX - $35,900 - Anaheim, CA - 1968 American Motors AMX "Go Pack" Matching Numbers Supercharged/Modified 390 CI Engine. Balanced and Blueprinted, Dyno tested at 469 HP, 514ft/lbs of Torque at rear wheels. Procharger Supercharger, 4 Speed Hurst Shifter, MSD Electronic Distributor, Holley 4150 Carb, Edelbrock Torker Series Manifold, Powermaster Alternator, Methanol Fuel Cell, and much more! Lots of $$$ put into this Motor. This AMX runs great and will put you back in your seat! Email for details.
Link to ad on Hemmings.com
All I see is a heavily junked-up AMX with a wasted-effort Procharger and cut-out Lund hood scoops installed reversed left to right, installed with a bunch of bolts or rivets. Running methanol it should be making a lot more power than that, but with that tiny fuel cell you'll never get far from home. Stoichiometric AFR on methanol is 6:1, so you use more than twice the same amount of fuel for the same volume of air to get a correct burn. I'm sure there's a bunch of power being left on the table here; the blow-through carburetor is one obvious failing but I'll bet he's running locked timing like so many idiots do.
A lot of poorly executed money. It's really a shame for someone to butcher this car in that manner. :(
