1967 Plymouth Belvedere - $26,595 - O'Fallon, IL - For sale in our Detroit showroom is a beautifully-restored 1967 Plymouth Belvedere II. If you want a show-quality race car that is still tame enough to use out on the streets then keep reading! The car has had the same owner for the last ten years and only has approximately 300 miles on the Pro-Street conversion. One of the first things about the car that grabs your attention are the huge 29x18.50 R15LT Hoosier rear tires mounted on Center Line aircraft aluminum racing wheels to shed weight. The car is covered with a stunning mirror-finish black pearl paint job on the all-original body with no filler that really shines outside and will be the center of attention at every show you take it to! With the sharp body lines sleek black finish and wild 60??s muscle car styling it is easy to fall in love with this car based on looks alone but the real treat lies under hood. The car is powered by a big 440 cubic-inch V8 with a steel crank heavy duty rods re-worked and port-matched 452 heads TRW aluminum pistons Purple 509 hydraulic cam Holley 850 carb Mopar M-1 single-plane intake Chrysler electronic ignition and coated Hooker Comp Headers. You get to slam through the gears yourself with a HEMI 4-speed and the power hits the ground with a Chrysler 8 rear axle assembly with 4.56 posi gears in a 489 case. The interior is finished off just as nicely as the exterior with a front black vinyl split bench seat that is comfortable for the long haul whether its your daily commute or a fun weekend road trip with friends and family. While the back wheelwells have been tubbed to clear the massive rear tires it was done in such a way that the full rear bench seat remains usable. To keep with the race theme the car also features a four-point padded rollbar that is tucked in close to the headliner to maximize headroom and legroom. The car also features a trunk-mounted fuel cell that still has room for the car cover and whatever else you want to store back there. Underneath the car has been set up properly with a 4-link rear suspension disc brakes at both ends and the entire car has been tied together from the front to the back so when you let out the clutch and put the pedal to the floor this Plymouth will hook up and put you back in the seat! When you??re on the gas the car rumbles through a 3? aluminized Flowmaster exhaust system so others will definitely hear you before they see you! Options on this street beast include: cassette player radial tires and racing wheels. This ??67 Plymouth is the perfect blend of show and go so call today to put it in your garage! Located in our Detroit showroom this ??67 Belvedere can be viewed in greater detail including HD photos and video at www.GatewayClassicCars.com or call (313)-982-3100 for more information.Link to ad on Hemmings.com
