1964 Plymouth Savoy
1964 Plymouth Savoy - $79,995 - Scottsdale, AZ - Professionally Built, 1964 Plymouth Savoy HEMI featuring Mopar Performance/World Products 'Dyno Tuned' 426 Block with 11:1 Compression, producing 668hp (603 lb/ft Torque) on Pump Gas! Stroked 484ci with 4.15" Stroke Crankshaft & 7.100" Manley Rods. Brief Sampling of this Impressive Build includes Aluminum Mopar Performance Heads ported by Ed Vickroy, Aluminum Crossram Intake, Holley 770 Carburetors, Electronic Chrysler Race Distributor with Tach Drive, MSD Ignition, Passon Aluminum Case Hemi Overdrive A-833 Transmission, Moser Dana60 Torque-Loc Differential w/4.10 Gearing (3.28 in 4th Gear Overdrive), TTI Coated Headers with 3" Stainless Exhaust & Factory Tips, 1/2" Stainless Fuel Lines & Sender, High Efficiency Cooling System with Four Core Radiator, 11 3/4" Chrysler Front Disc Brakes w/11"x3" Rear Drums, Dual Master Cylinder Brake System, Stainless Brake Lines, and Custom Steel Wheels (Front 16"x 4 1/2" Rear 15"x10"). Stunning Ebony 'Show Finish' surrounds Factory Race Hemi inspired Custom Interior features A-100 Seats, Column Mounted Tachometer with Under Dash Auxiliary Gauges, and Custom Wiring Harnesses. This Remarkable Build has been Documented with Comprehensive Hard Copy & Digital Files of Photography, Correspondence, and All Invoices. This Savoy HEMI is 100% Road-Worthy, has been Driven 495 Miles, and is Perfect Throughout. An Outstanding Mopar Collectible, that can be Driven Anywhere!
Link to ad on Hemmings.com
