1949 Plymouth Suburban
1949 Plymouth Suburban - $20,975 - Sioux Falls, SD - ``RARE`` !!... 1949 Plymouth ``P17 Suburban`` 2 Dr. Station Wagon !! Just 44 K on it`s clock and well taken care of. High gloss ``Mexican Red`` finish showing minimum patina.Fresh, matching interior.Nice chrome and bright work with good fit and trim. The folding seats give it plenty of utility use and is also a people mover !!.Nostalgic travel stickers line the rear side windows from it`s many travels across the U.S. A. !! Powered by the 217 C.I. 6 cyl. w/ 97 H.P. A truly fine example all freshened and gone through. Equipped with : heat / defroster, wide white newer tires, factory wheel covers / trim rings, rear fender skirts, AM fac. radio, rear hatch, dual bench seating,and more !!!...Starts, runs and drives excellent !! Ready for it`s next road trip with it`s new , lucky owner !!.. * ``SPECIAL FINANCING`` - Qualifying vehicles : 1975 or older vehicles - 4.99 % up to (5) years -20 % min. down payment - With approved credit - No prepayment penalty . ``Discount`` shipping is offered worldwide and can all be set up for you. Ask for a quote !! Thank you for talking a look and we would be happy to answer any questions you may have. 1949 Plymouth Suburban Specifications : The power train was a 217 cid, with horsepower up to ninety-seven. This change came about through a newly designed cylinder head that raised compression from 6.7:1 to 7.0:1. A new intake manifold provided better distribution of the fuel-air mixture, fuel pump capacity was increased, and a fully automatic electric choke prevented ``over`` choking. New oil control rings with wider drainage slots and a chrome-plated top piston ring, along with improved crankcase ventilation, were also claimed. A larger starter motor, resistor spark plugs and weather-proofed ignition system aided in cold and wet weather starting. The landmark offering had to be the new all-steel two-door Suburban. With the rear seat in place there was 42 inches of cargo space available; with the seat folded down, another
Link to ad on Hemmings.com
Yeah, it's funny how a roofline can change everything. The sedan looks wretchedly terrible. The wagon looks both stodgy, and cool.
I was on board for this one, but the welded-up-and-not-painted bellhousing is just plain frightening.
By the late 40's Mopar's were using the "open bottom" bells, so that would be the inspection cover.
Regardless, something broke or blew apart and they didn't even bother to paint a shoddy repair.
