b-body-bob
I removed the shifter and 4-speed hump to come up with an idea of how to install the shifter without making a mess of the carpet and allow the carpet to be used in the future if/when I switch things to a small block 4-speed. The hump was held in with sheet metal screws and stickum, so I pulled the shifter and hump off in one piece to give easy access to the shifter bolts.
The best idea I've been able to come up with for the carpet so far is to put in a neat round hole, and use a grommet when the cable is needed and a plug when it's not. Cut a neat(ish) X in the carpet for the cable to exit through and slap some gaffer tape under it to close it off when the cable isn't needed. The cable has to exit the front of the shifter so there's no way to run the cable completely under the carpet.
I'm also thinking of fabbing up a mounting bracket so I can limit the shifter bolts to being just in the cover over the 4-speed shifter opening. Right now it bolts to that and to the hump itself.
In other news, I might have figured out why you can't buy an A-body lower fender brace thing (between bottom of fender and bumper bracket). I found what should be a b-body part, and it fits too, so there might not be a specific A-body part. I need to find one that for sure came off a b-body to confirm it though.
I also pulled the distributor out and gave it a close look. It doesn't seem like there's any play in it that would contribute to the jumpy timing. That is not good news. I'll follow up on that more once I've got the shifter reinstalled so I feel safe starting the car.
