Dr.Jass
Pastor of Muppets
As far as the hose to the carb, just bend up a steel piece and use rubber on either end. That's what I did on mine. It's still semi-hokey, but I don't trust rubber hose... at least not for long. I try to keep its length as short as I can wherever possible. I don't even really like the -AN braided stuff I have from the tank to the pump, but I couldn't find 1/2" steel tubing easily.
What I do trust is nylon oil-pressure tubing. I've never seen it fail, though I've heard of it melting when someone stupid enough let it rest on something hot (hint: the block doesn't get hot enough). I even know of an instance with sufficient pressure to blow apart the brass bourdon tube inside the oil-pressure gauge but the nylon held just fine. What I have seen is copper work-harden and crack due to vibration. It's admittedly pretty rare, but leave a nice gradual bend, maybe even a loop like brake lines leaving the master cylinder, to absorb vibration over a greater length. The "nylon is failure-prone" thing is a wives' tale that persists without reason or logic.
It's always the little shit you don't consider that kills the budget. Fittings, sealant, hardware, $500 driveshafts...
Like your blue pump, the noise from the Carter pump goes away when the Valiant's started. Unlike the A12 car, the Valiant has full exhaust with mufflers and resonators, so it's pretty bearable inside, even without the back seat (under which the pump is mounted).
It sounds like a productive day... wish I could say the same. *taps foot waiting on parts*
This made me giggle, likely because I pictured a big ol' grin on her face while she was doing it. Glad to hear the pressure looks good and that you've got better results in the smoke and vapor departments than I.Gina hopped in and revved the shit out of it for a while so I know there's no smoke, black blue or white, with it warmed up running in the garage, and there's no unburned fuel floating around in the air so that's good. Fuel pressure bounces between 6 and 8 with the car running.
