thrashingcows
Drowning deep in my sea of loathing...so I'm
Seems Demon carbs has come out with a new revolutionary design....Looks rather familiar to me. :hmmm:
Here the link...
http://www.barrygrant.com/1901.asp#1
- 625 CFM air flow - ideal for use on most stock to mildly modified V8s
- Dual mounting bolt pattern - fits any street 4bbl intake (square flange or spread bore)
- Electric Choke Management means easy cold starts
- Single fuel inlet for simple installation
- Aerospace Composite fuel bowl offers significant heat insulating benefits over aluminum fuel bowl - keeps fuel up to 20º cooler for optimum performance with modern fuels
- Integrated fuel bowl/main body design with gasket above fuel level and no plugged passages to eliminate all potential leak paths
- Small 1-3/8” primary throttle bores combined with proven Triple-Stack™ boosters deliver amazingly crisp throttle response and drivability, superior fuel atomization and improved fuel economy
- Goggle Valve Secondary (GVS™) throttle plate delivers over twice the air flow of the primary bores for power you can hear and feel
- GVS™ makes total air flow 625 CFM while maintaining the crisp throttle response delivered by small primary bores
- Secondary air valve control - torsion spring valve control/adjustment permits seamless primary to secondary throttle response regardless of the throttle opening rate (unique contoured profile developed for better cylinder to cylinder fuel distribution)
- Smooth styling - patented timeless design fits modern as well as traditional themed vehicles (Patent No.: US D648,746 S)
- Developed from the ground up with great looks and ease of use in mind
- Easy to clean and maintain
- One-piece air horn assembly
- 2 Stage metering rods control easily accessible without carburetor disassembly or removal
- 4 optional vacuum step-up springs available to dial in hi-end performance
- 8 optional sets of metering rods available to refine calibration
- Multiple primary and secondary main jet orifice sizes available
- Patent pending mechanical design
- Integrated 700R4/200R4 transmission kickdown cable mounting location for proper shifts
- Ford A/T kickdown (does not work with AOD transmissions)
- Available TPS kit allows use with 4L60 and 4L80 transmissions
Here the link...
