I did this yesterday (it's finished now)
People freak out about clamping it. If you clean the car and seal both with wax/grease remover, put glue on both parts, wipe it around, and press the seal down really good, it ain't going anywhere. Promise. https://www.youtube.com/results?search_query=steele+rubber+products+videos especially this one
Another freak out is OMG don't get it on the paint. It wipes right off with a little wax and grease remover.
I also wondered why are we still doing this the hard way? Me, I had a trunk seal I bought about 20 years ago for $15 IIRC, so that's my reason. Yesterday I realized you can get a good quality peel and stick seal for $80. That is the way unless you're going to judged competitions.
If my work doesn't stick, I won't waste my time with this tube of glue stuff again.
A bunch of parts arrived today (Sunday? Guess so.) However, the 3/8" fuel line kit arrived without the ferrule to AN fittings. That fuel line kit will have to get reordered once I can get Amazon customer service to reply.
With the fuel filters and bulkhead pass-through fittings here now, I was able to finish fitting the nutserts in the mounting brackets. I also drilled two holes for the pass-through fittings. I'll weld the mounting brackets in place tomorrow after the paint dries.
A couple friends stopped by today to help me get those stuck wheels off the car. We tried a bunch of things, a dead blow hammer, a bottle jack between the frame and wheel, heating the spindle with a propane torch to soften up the powder coat, even dropping the car off the floor jack onto the wheels (with the lugnuts on loosely) and the cranking the steering wheel back and forth. Nothing worked. As a last resort, I tried removing the spindle nut and outer bearing, unbolted the calipers from the spindles and then unbolted the soft lines. With the bolts out, I was able to barely slip the caliper around the spindle just enough to allow the whole wheel, rotor and caliper assembly off the spindle shaft. If the wheels were any smaller in diameter, I wouldn't have been able slip the caliper past the spindle cabore.
Tomorrow I'll bring the front wheels to a shop somewhere to get the wheels onto a press to get the rotors off of the wheel center bores.
I'm sorry that's funny, pulling the rotor off because the wheel is stuck on it.
I remember having a battle with the well-known stuck rotor on an early 2000s ram. Yeah the wheel would come off but the rotor wouldn't. You tried it with no luck but there was a bottle jack and a lot of patience involved.
I got a local shop to press out the rotors for me. I asked them to also turn the rotors afterwards, but they didn't fall within spec. Minimum allowed rotor thickness is .940, and the first rotor we checked finally started to clean up at .915. One of the rotors also had a huge (1/8") crack in the outer bearing race. That same rotor also has a huge chunk missing from the outer edge that went into the path of the pads. So now I need new rotors, bearings and seals before I can roll the car around much. I'll still use the old rotors to hold the roller wheels on the car for now, but they're destined for the bin.
Didn't get pics yesterday, but here's a pic of that cracked outer wheel bearing race.
Today I got the fuel pump, filters and fittings brackets placement sorted out. Two of the brackets required holes in the crossmember to clear the rivet nuts. The brackets were then aligned, clamped in place and then welded to the crossmember. Next I ground the high spots on the top edge of the welds so they wouldn't hold the floor metal up over the top of the crossmember. Lastly the welds all got a coat of rust reformer.
Tomorrow I'll start making the PTFE fuel lines.
I wanted to start making the fuel lines and got tired of waiting for the proper AN wrenches to arrive in the mail, so I used Crescent wrenches instead. Those wrenches worked on the first two lines fine, but scarred up the surface finish in the process. I'll wait to do the others until after the AN wrenches arrive.
The two lines I assembled are the feed and return lines between the tank and the bulkhead fittings.
If you have a full selection of metric & SAE box wrenches you should have non-adjustables to do the job.
I was in a hurry to try it and my combo wrenches are all scattered around the shop at the moment. I need to do a full shop clean and sort.
I found enough combo wrenches to start tightening the AN fittings on the tank. The two lines I made earlier are attached at the top of the tank, but not at the bulkhead fittings yet. I made those two lines long enough to be able to drop the tank without having to disconnect the fuel lines first.
Cleanup tomorrow and then more progress on the lines afterward.
I found a steel wrench, combo or crescent, will tend to mar at least the anodize on AN fittings. The AN wrenches are aluminum. No I didn't buy a set either.
I can deal with the wrenches marring the fittings, as long as the lines don't leak. Hopefully the AN wrenches I ordered will arrive tomorrow and I'll be able to get back onto making, rather than mangling, the fuel lines.
I did get most of the garage cleaned up today, but not all of it. There's just one corner left to get sorted out. I'm trying to find a solid work table, for my metal brake, to stick in that corner.
Too bad you're not here, we've got at least one solid core door I'd give you to build that table.
I've built a door type bench before and they work great. If I don't find something worthwhile on FB Marketplace soon, I may just build one again instead.
A few parts orders arrived today, but not the ones I need right now. Still waiting...
I think I'll reinstall the front rotors and then put the rollers on all four corners. Then I'll be able to weld in the subframe connectors. They'll need to be welded in before I can know where the fuel hard lines will run.
I've been unsing a layer of painters tape on the fitting. The cresent wrenches just smooshed right through it. Duct tape would probably be more protective, but the residue is harder to remove after getting smooshed into the metal. The AN wrenches should be here either tomorrow or Monday, so it's almost a moot point now.
This is what arrived today. Some 6AN fittings, a fused relay box, tubing straightener, AN wrench, fuel regulator and some 3/8" P-clamps for the fuel feed hard line.
I started out today by swapping the 45* fittings for straight fittings on the bulkhead end of those first two fuel lines. They fit better and the lines don't look like they'll rub the subframe flange anymore.
Moving on to the front wheels and brakes, I put the rotors back on the spindles first. The pass side hub, the one with the cracked bearing race, is junk. The saddles for the bearing races are wallowed out bad enough that the hub goes from either all floppy or locked up. There's not much of an in-between setting unfortunately. So, the hubs are also getting replaced in the near future. For now, I left the wonky hub tight, but still able to roll. Barely. The roller wheels are also back on the front. The rear roller wheels will go on after the PTFE lines for the fuel pump and fuel filters are made.
It was perfect weather outside for a change, so I opened the garage door and sanded the other half of the hood. The paint on the driver side of the hood was just as bad as the other side. Under it, there was the same rust spotting, but not the rust pit cratering like on the pass side. There was a large bondo patch over the hood hinge area though. I left it alone after getting it smoothed over. Then the rust reformer came out. I still have a single strip of tape running down the centerline of the hood. I left it there because I plan on cutting the hood open for a bug catcher scoop in the future. Until then, I wiped off the hood inserts and set them in place to see how they look there. They look ok to me, but a bit boring IMHO. The carb scoop will fix that. 👍
I wanted to get more done today so I went back out to the garage after dinner.
I made up three AN PTFE lines to suit the existing connection points. Each one was made so they had just enough wiggle room to allow me to thread the fittings onto the filters and pump. I did unbolt the fuel pump so I could get a P-clamp onto the lower bolt, so that simplified hooking up the shortest line in the middle.
All that is left to hook up back there is the two hard lines. The aluminum 3/8" line comes off the exit of the fine filter, and the 5/16" return line goes to the bottom bulkhead fitting. I'm going to run both hard lines straight to the fuel pressure regulator in the engine bay. There's only about 18" left of the PTFE line left, so I'll need to get more of that to make the last piece of line from the regulator to the carb.
BTW: The middle pic is reversed. I had to flip the camera and hold it under the car to get all the lines in the shot.
Today's main job was getting the driver floor prepped so I'll have clearance to weld in the subframe connector.
First I yanked out the three remaining seat belts to get them out of the way. That took way more effort than it should have, because someone welded the exhaust hangers to the ends of the rear seat belt bolts. The breaker bar was stronger than the weld, so the exhaust dropped as soon as the welds broke.
Next step was to remove the remaining fiberglass from the floor before the cutting started. I also removed the body wiring harness to get it out of the way. Then came the angle grinder to remove the majority of the rusty floor, leaving the area under the front seats to maintain some rigidity. That remaining center area is all just some flat sheet metal that was hammered by hand into the approximate shape of a Barracuda floor.
Tomorrow the rear roller wheels go on and the car gets put back onto the floor.
