After I talk to Don's guy maybe I'll bring em both down & get estimates on both , then decide which to have done?
Midland is an industrial radiator shop, hoping he’ll deal with an old school setup like this.
made my first slice in the front to try & get that closer to laying out nice
So I dug out the floor bracket & put that in.
I'm thinking I better get the brake booster & pedal in before I muck things up with the column.
& got the jute glued on the back of the divider & stuck that in.
And yet another little job I managed to make more difficult, should have put in the proportioning valve & brake lines in while the bay was empty!
Believe it or not, those plates were part of the "increased rollover protection" scheme implemented in 1973. Chrysler put them where they found the body would buckle, allowing more collapsing of the roof in a rollover. It was another requirement of the Federal Motor Vehicle Safety Standard change that also required the buck-tooth bumper guards on 1973-'74 cars. They did not exist on 1970-'72 cars.Is there any point to me putting the steel crash plates back in by the quarter windows, don't care bout weight I'm not going racing? View attachment 26443
It's exhausting to install things just to remove them later, amirite?have to pull the fenders to put the corners in
That's why I was thinking about converting to hydraulic while the engine's out. I'm resisting the urge to strip and repaint while it's out because that's the road that leads to restoration hell, but will definitely spend time with some goo-gone and a rag wiping off as much of the spray bomb black as possible.should have put in the proportioning valve & brake lines in while the bay was empty!
As usual there is a piece left over, this little clip, it was in the bag with the motor hardware................
Does it go over the nut that holds the rod to the motor, I can't see any other place for it?
