Now I wait & see if the new arm is up to par or a sheet metal knock off???
I'm sure the parts I got from Dr Diff are the same, and I thought the same thing. Then as soon as I bolted it all up and put it on the ground the tie rod boots ripped. Didn't even get to drive it first.A lot of the front end rebuild kit came from Taiwan, considering the low mileage I will put on I hope they will outlast me or my ownership which ever comes first!
Most people want to sand chrome with 80 grit, but since chrome is hard, 80 grit doesn't really abrade the whole surface. It's not a hard job, just awkward.Looks like I'll try with the glass in, on the chrome I'll start sanding a bit & see how terrible that job will be.
Thanks Resto your a fountain of good information!
They are standard but there are a couple of different sizes. The one you have should work, but if not you can get them at any parts store, and Harbor Freight sells a kit of various sizes and shapes.I hope there standard I can use the one off the ball joint that came in the front end rebuild kit?
