b-body-bob
The parts car is 3 on the tree.
The Duster has a shift kit in it that will hold in gear when it's not in D until you shift it and it was brutal when driven that way, although while I had it all apart I found the throttle lever was misadjusted so it might be all better now. Of course a RMVB doesn't use a throttle lever ...
I've got a full automatic valve body here too, but there's a chance I would have to un-modify things in the trans to switch to that. Seems like I remember the governor is gone and the accumulator is blocked.
The A12 trans has a PTC converter that I was told behind a 450 hp motor in a roadrunner: "The converter you have should footbrake up to 2 -2500 and flash 35-4000 behind your setup."
I've also got what I believe is a /6 converter that was installed when I bought it. It could be a J converter but I'd have to dig it out to know and right now I don't care that much.
Also I keep trying to setup a wish list at Dante's so I can make a big interior parts purchase and it's broken his website twice. The first time it happened his "IT team" made a code change and re-did my account, which worked until it didn't again. There's nearly a year wait on seat covers.
