Stretch
Hey! There’s no easy button for a body like this!
I should clarify. I just have a mid lift. I had the car just far enough off of the ground to slide under it on my side on a creeper. I have been lifting this car on that lift for months. I set it down when I'm done working on it for the day because it flexes and the body structure is wood and its a roadster so it moves. For what ever reason I got carless and didn't check the lift points this time. The problem. Started with wheel doilies. I set the car on them when the hoist is down because i used them to locate the car over the lift. I check it every time I lift it except that one time. I lifed it. Layed down on the creeper and slid under. I rolled to my side so I could reach the fitting for the fuel gauge. On the top of rhe tank. Thats when I hraabed the leaf spring to pull myself a bit to the side. I didn't move. I did however pull the car off of the lift and onto my sholder. I was pinched between the fuel tank and creeper. I rolled over and slid out. Collected my thoughts and went un the house.
