Yoo-hooooo! Stretchy poo!
Hey, you said you were needing small projects...
Wanna finish disassembling my front suspension for the LeBaron? Or is it not possible to dig it out?
Well! I’m not sure. Let’s see if we can find it.
Hmmmm, I'm not seeing it...perhaps one of these will help.
:D[smilie=g:
You can see it all the way to the right of the pictures, below the coiled-up extension cord, leaning up against the front framerail of the LeBaron! It's partially hidden by the Parts Express box and a lawnmower handle... See? See?!
The problem I have is cutting off the lower-control arm bolts to which some jackass welded the nuts... tried grinding through one of them, but they're apparently hardened, and not easily cut. The rest of it's all bolt-on stuff, I think.
I also need to know whether the lower ball joints are threaded or press-fit so I can order new ones.
BTW, for those of you who may have an FMJ car, don't start tearing apart the suspension before pricing all the parts. Holy crap, they're expensive to fully rebuild (all the bushings and such). I'll probably have around a grand into everything. :eek: :doh: If it doesn't need replacing, don't take it apart. 20/20 hindsight.
Awww jeeze, I thought this post was about something else...... and I was gonna show off what I dun in the toilet this morning. :(
