71Satcloned2runner
Raodrunners Rock!
Well,
It's now in the shop and getting done. For spring I need to:
1. Rear main seal leak
2. Tranny pan new gasket
3. Rear diff leak (gasket?)
4. New ball joints in front suspension
5. Reverse light switch installed
6. Pump and container hooked up to wipers
7. heater won't work (likely fuse)
8. Drums and discs need grinding etc
9. kickdown linkage installed
Also, any of you carb guys know why I might have a GM carb on my 400 engine from a truck? I need to find a throttle cable for it. Need to know what kinds of cars I can get them from.
Can anybody tell me what good looks like in regards to the bushings on the control arms? Mine has a small crack, but no real wear other than that on them. I had a mechanic tell me that frame sag is the most common problem on old mopars, and he recommended I change the bushings while the joints get done. Agree? I am not looking at doing them right now, as the mabour on that would be real pricey. Not sure if I can do it myself.
PLease advise, as my bill will be a ton of money, and any job worth saving is good for me. I can show a copy of the estimate for all of you if need be tomorrow.
Cheers,
71.[smilie=2:
Cheers,
71.[smilie=2:
