MoPar_Jamie
Well folks,
I FINALLY got to get started on my '79 Volare Duster project. Today was kind of productive, got the motor ready to come out (junk Slant Six, hole in block!), also stripped down the '79 Aspen V8 K-member that I want to use. The car it came from was wrecked in the back but it drove pretty straight and didnt wanter a bit. BUT, I decided the heck with it and am going to completely re-do that whole frontend.
I'm going to add cop bars (different rubber bushings), a cop box, and some HD tie-rod ends. For the brakes I want to add some 11.75 rotors and some 11 inchers out back.
I also want to eliminate the rubber bushings that isolate the K-member from the chassis.
For the rear suspension I'm going to add some cop springs (out of that same ill-fated '88 Dippy) and probably an 8 1/4. I want to eliminate the isolators as well.
Next step is to get the engine out and take the car to the carwash, along with the subframe. Then I'll park the car in the shop and go to work. Want to detail/rebuild the suspension over next week if I can.
For now I want to use an '86 318 with a better cam and a 998 trans. Definitely will get a 4-v setup and probably a 600 carb.
Lotta work but I've been wanting to do this one for awhile. Here is a crappy pic of the car taken when I got it:
