"wanted" hot tub tech(now with pic's)
69.5CUDA
Blah Blah Blah
we got any "older" hot tub techs around...picked on up for free ..and then picked up a working heater/pump/air comp/filter thats working but COMPLETLY unwired.....
wireing it to the house i understand...wireing its fuse box back together along with its controls...i dont...however it looks rather simple
I think Kam is more in the chemical side of the biz, Greg is a tech. I was a tech for about 8 years, been away from it for about 10 years, so I'm probably gonna be a tad rusty with the tech stuff, so call on the pro's
well mr 340 then your proly who i need to talk to as you would likely be " in the know" on the tub as best i can tell its dated 85ish
looks like it might be time to post me up a "pile o pic's"..asumeing xl dont mind....since ya cant post em thru PM's
mind you this is a "low buck" late B day present for my wife to help with all of her back problems
do you know who made the tub, and or a model#?
all the electrical components ie: pump, air blower etc. should be wired thru air switches for control inside the tub. seems like it will just be a matter of hooking the right switch to the right component. Pics would be very helpful, if you want you can e-mail them to me (pm for e-mail addy), and if I can't figure it out, i'll pass them to greg.
all of the componenents on the "skid"? are all "sta-rite" with the exception of the air comp being anzen
..tho the "fusebox" on the skid is well.....unwired/empty except for 2 air switch relays? and the timer...the only name i could find on the tub(tho i cant say i would know where to look) is "sanntanna" on the little unscrewable (jet preasure?) cap..and a jacuzzi overflow box
Hey 69, you can post whatever pictures you need to my friend! :)
*edit* NO nudes of you and the wife in said tub, k? * :D
asumeing i could get the camera out there with her in the tub...then back in the house befor being killed
[smilie=e:
here ya go tech's
here is what your looking at..skid as ive come to call it looks to be a hard black nylon plastic with all the components mounted to it ..but mostly look at the fuse box..its er umm empty with only 2 air controlers of some kind and a timer
next we have the inside of the cover of the fuse box
next is a close up of the stainless filter can
Can you get a closer shot of the control box, and is there a diagram on the inside of the cover?
next is an air/relay..or atleast thats what it seems to be with a nipple outside of the fuse box
next is the inside of the heater cover(right and left pics only way i could get it in focus)
can you also get a pic of the actual pump motor wiring, so i can see if it's hi or lo volts... ( it's a dual voltage motor)
if there was a diagram in the fuse box...i wouldnt be here LOL
hmm close up shot..i think i have one
the nipples are the air switches, there should be 2 or 3 of them there. they will control the pump speed and the blower from a pad on the tub.
im going to asume i need to pop off the back of the motor to see its wireing yes?
...screwdriver in hand digi cam ready
there is only 2 air switches..and sadly no control panel
