These might be a little less, because they haven't been hand blended after the cnc porting. I think I can afford a little less flow. I'll still scare the 'crapp' outta myself.[smilie=2:
What....is....a....chamber.....port......for. How....do.....you.....plug.....the.....hole.........that.....is.....left.....behind.
No little green aliens here
These heads were used briefly on a run-in stand, so I think the probe was to measure comb. heat so they could better figure the fuel/air mixture. The hole can easily be plugged with a set/grub screw. Just like the airpump holes on sb truck heads.:doh:
