truck needs shocks
73clubcab
New member
Need help trying to figure out what the weight rating is for my front axle on my 73' D200 2WD 3/4 ton eight lugger.Is there some way to figure it out from the vin# or by looking at it?their are two listed and each takes a different shock.
There's nothing in the VIN of which I'm aware. There should be a label on the door jamb with GVWR front, rear, and total. It's sometimes a metal tag (it was on my '78). If it's ex-military, odds are pretty good that it's a 3,800/4,000lb axle but it's no guarantee. If you can't find the GVWR tag, there's no way to know without component comparison. Pretty simple, though: remove an old shock. If it's 13.375" long extended, it's the lighter axle. If it's 15.5" long, it's the heavier one. My '78 D200 was a Slant Six ex-USAF truck and had the heavier front axle. 15" wheels would not clear the brake calipers.
