Trial fit of the NEW 408 engine
kamstra
I think it will look good here
Thanks, with the big oil pan, I had to notch the k frame
I still think I need to cut a little bit more.
I HAD to try the TTi Headers on, just to see the fit. Boy they are a quality piece of equipment. I also added a Carter Street Fuel Pump.
I like a man who says "only" & then lists enough work for a year or so(at least on my sched.) Looks purty! Rich.
The rad is done but the old 318 crank pulley doesn't line up to the 340 crank pulley. The holes are differnt so some modidications are in order
Engine came back out, and the k frame notched some more. I removed the 90 degree adapter and used a straight short oil filter
The existing manifolds are in place until it is broken in and then the TTi's will go in
Ahhh, NOthing is a direct fit. I modified the existing throttle bracket for the taller Air Gap intake. I also got the vacuum line plumbed up with some brass plumbing fittings for the onatke manifold.
Waiting for the delivery of the clutch fan. Slow but progressing forward.
Firefighter came for a visit and we re and re the engine, installed the tranny and the TTi's
Little Mikey helped out for a while too.
Here isthe rebuild Street Strip tranny and Turbo Action hemi converter
