Some Good Advise.
Diplomat_Wagon
Hiding In The Bushes While
:bwuhaha:
1. If you are choking on an ice cube, don't panic. Simply pour a cup
of boiling water down your throat and presto! The blockage will be
almost instantly removed.
2. Clumsy? Avoid cutting yourself while slicing vegetables by
getting someone else to hold them while you chop away.
3. Avoid arguments with the Mrs. about lifting the toilet seat by
simply using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed
for a few minutes, thus reducing the pressure in your veins. Remember
to use a timer.
5. A mouse trap, placed on top of your alarm clock, will prevent you
from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you
will be afraid to cough.
7. Have a bad toothache? Smash your thumb with a hammer and you will
forget all about the tooth.
8. Sometimes, we just need to remember what the rules of life really
are: You only need two tools - WD-40 and Duct Tape. If it doesn't move
and should, use the WD-40. If it shouldn't move and does, use the duct tape.
9. Remember: Everyone seems normal until you get to know them.
10. Some people are like slinkies..........they are not really
good for anything, but.....they still bring a smile to your face
when you push them down a flight of stairs.
#3 I've thought about that...but decided it was a bad idea.. :shifty::bwuhaha:In a pinch I just go outside and off the back deck... :shifty:
#5 I NEED to do that!! :hmmm:
#9 Yeah that's how I feel about everyone here!! :shifty:[smilie=f:
#9--- I,M WIERD THEN YOU FIND OUT I AM NORMAL----FISH VOUCH FOR THAT WILL YOU ?hahaha---no joke... #2---i don,t cut vegatables - i leave them in the wheel chair---hahaha #7--- what happens if you have no teeth and you have phantom pains.. pretend to hit your finger? --lol
fishy you just need my alarm deck...its a tape deck with a timer built into it thats designed to be hooked up to high end sterio systems...set the timer and turn the deck to the desierd volume..even crank it if ya like...after useing it a few times you actualy start wakeing up 10 mins early to shut it off befor it goes off
Or I cold just have you pounding on my door while I mumble about Lamborghini's in my sleep. :shifty:
