Smallblock stuff.
Mark Nixon
The Best Fun In The World Is Right There,
1970 340 block, needs 2 sleeves, may clean at .030, as-is, $75.
1971 340 block, missing caps, needs 2 sleeves, may clean at .030, as-is, $65.
1973 340 intake, SOLD.
1973 340 heads, # '587 have had water in them, as-is, SOLD.
1978 360, complete runner when pulled, very tired, needs rebuilt, $125.
1990 '308 heads, have minor cracks, machine shop says they are okay as-is, $60/pair.
Complete 1975 400, sell as-is for $150 or bare block for $100.
Bigblock '452 heads, $20 each.
1965-'67 273 Hi-Po pistons, STD bore and in good condition, $100/8.
1965-'66 Commando 273 valve covers, need restored, comes with both chrome caps for PCV and oil cap, $125/pair.
1970 318, under 75,000 miles, ran when pulled years back, $75.
Contact me by e-mail at Nixon340@yahoo.com or by phone at (402)-780-5127.
hey mark just outa curiosity whats the diferance between a stock 273 piston and a high pro...im asumeing just compression but how much?
69.535698552CUDA said:
...whats the diferance between a stock 273 piston and a high pro...
This is an easy one!
273 pistons:
Hi-Pro:
See, one's a piston, and the other is dog food. :D
ROTFFLMMFFAO!!
Jass, send me sumadatstuff!!!:dance:
69.5, the 273 Hi-POs have 2 valve reliefs and a small pop-up dome, the non-HP ones have 4 valve reliefs.
The compression on the HP ones is @ 10.5:1.
Mark.
rofl, Jass, you are too funny!!!!:bwuhaha::bwuhaha::bwuhaha:
Will the 340 intake and heads fit on a 318? Intake is 4 bbl right? I have a 74 318 and managed to find a 74 360 carb (4bbl)
The heads are the 1.88 intake valve and would work decent on a 318 with either a .030 cut off the cumbustion chamber, or use a slightly higher compression piston.
These heads need evrything to do them right, valves, springs, retainer, etc.
The intake is a 4 barrel one.
Mark.
The heads and intake I had listed sold last night.
I do have some other heads to go through and I might have a later 4bbl intake.
Shipping to "TGWN" would be pretty spendy, I would think.
Mark.
