MyBigBlockDodge
Screw it. Give me the red AND blue pills.
I'm having a problem with rough idle and/or missing, but only at idle.
Pulled the plugs and all look good except two that were darker then the rest. Put new set of plugs in, replaced plug wires to said plugs (even though the wires on it are practically new), adjust carb slightly (stuck a vacuum guage on it and set idle mixture). Fired it up and it ran great. Drive it around the block and by the time I get back the idle is lower (from about 700 to 550 in gear) and it's running rough at idle. Rev it up, and it's smooth as glass.
My thoughts... idle circuit on carb (750 vac sec Holley) or an actuall ignition issue. Secondary thought... vacuum leak?.
I've been trying to get it through emissions testing but keep failing the idle HC's (i.e. ignition problem etc).
I know there are many possiblities, but I'm looking for some ideas here to see if I'm on the right track. Ignition componants maybe?
Thanks in advance,
Adam
**update**
ok.. narrowed it down some. Carb issue from what I can tell. I sprayed some carb cleaner at the air bleeds (yeah I know should have done that before putting the new plugs in) and that seemed to help out almost immediately. Pulled the fuel level plugs and lowed the front bowl level slightly, left the rear where it was. Seems to run rough when first started after sitting so I may have a bad needle/seat, but I'm not seeing any black smoke when started or while running/reving it.
Going for a short test drive again so we'll see if it starts missing.
Thanks in advance,
Adam
**update**
