project74
Trying to find my weed and
I may have found the 8.25 I need but could really use some ideas/advice so once again I shall probe the boundless intelligence and limitless ingenuity of those who inhabit this strange yet beautiful place.
(Sucking finished):xl:
Option 1 is an abody unit that was rebuilt in '98 with a new Auburn sure grip unit and a set of Richmond 3.55 gears (the gearing I'm looking for). It has limited miles on it though those miles include several strip runs behind a stout 360 and some time spent on a circle track (not good for the bearings I'm sure). It's a 3 hr drive to go have a look and no brake parts are included with this setup. (No pics available)
Option 2 is also an abody piece that according to seller (who I've heard is reputable) is perfect/A1 and in a daily driven car. A true bolt in. Only catch is that it's an open diff with more of a cruising gear. Brakes are brand new in the last year and I could pick it up in 45 mins.
Here's the dilema. Both rears will cost me the same coin other than the full day's gas money to go view option 1. Option 2 will definitely need a gearing/diff change but that's it. Option 1 could also need this if things burn up on me in a short period of time and a full brake job will be a must. Not meaning to be too blunt but WTF would you do? I have no idea of how to check a rear to see if it's good or not so any help here would be much appreciated too. Things to visually look for, physical tests that can be done, that sort of thing.
I've already considered buying both to make one but that's above my current range so hold that thought :dgt:. I've also wondered if it would be more to my interest to just do a rebuild on things like diff, gear/pinion and bearings no matter what I end up with.
Okay, I'm done with the ramblings. Once more I bow to your eternal wisdom in these matters and turn the ball over to you.
Much thanks in advance.
