Rattler pics for RAV440...
snook
Here you go Randy:
:bravo: thanks SNOOK :bravo: the pulley bolt hole look the same . i presume grinding the bolts down didnt effect the balance , being you were zinging more Rs than i would ever think aboot [smilie=2:
:bravo:
Is your motor externally balanced? You mighyt want to check with TCI to see if this is a fit for you. Considering that the internal weights 'rattle' around (and you can hear 'em when you start it up), balance is not an issue, I think it finds its own. ou could always get more bolts from TCI if it bothers ya.
it didnt bother you did it ? so it wont bother me . :bravo:
