Mark Nixon
The Best Fun In The World Is Right There,
1 set of A body 4 inch bolt pattern Rallye wheels, with '72 centers, have decent trim rings and caps, need restored, $400.
A body 8-3/4 axles and backing plates, small bolt pattern, $110.
1994 360 Magnum longblock, partially dis-assembled, needs intake and oil pan re-sealed, decent rebuildable core, $350.
11" Flywheel for a 360 Magnum, needs surfaced, $100.
Steel RB (413 or 440) crank, nice, low-miles Standard crank that may or may not need turned, $150.
'LY' rods for above crank, low miles virgin originals, $60.
Oil pan and windage tray for 360 CAR applications, comes with main cap bolts and pick-up screen, $80.
340 windage tray and main cap bolts, $45.
De-stroked 360 steel crank, makes a 340 out of a .040 overbored 360, .020-.020 undersized and rready to run, $125.
STD bore 10.5:1 340 pistons, nice USED condition, w/NEW RINGS, $60.
Heavy Duty Motorhome Big Block 727 transmission, super low miles, worked when pulled, NEVER OPENED UP, has the early 4 planetary gearsets and the better front and rear apply servos, $150.
Manual transmission conversion for 6 cylinder, consists of: Bellhousing, Pedals, Z-bar, ballstud for frame and bell, pedal pushrod and other CLUTCH linkages, $200.
3 speed-on-the-column steering column, manual steering, works good, $80.
V-8 Bellhousing, fork, ballstud and lower cover from a '72 340 4 speed, $125.
10-1/2" flywheel, $65.
ALSO PARTING A 1967 AND A 1969 VALIANT , BOTH 2 DOOR SEDANS, 1967 HAS RUSTFREE 1/4S, FENDERS AND INNER FENDERS. 1969 HAS A DECENT GRILLE AND DECKLID.
BOTH CARS HAVE MANY, MANY OTHER GOOD PARTS!!!
Contact me by e-mail at Nixon340@yahoo.com or PHONE me at (402)-780-5127.
