Best recipe of which I'm aware for porketta roast... and if you've not had porketta, let me know where you live so I can avoid hell.
First off, ask around and find the best butcher shop in your area that does Italian stuff. If someone has a recommendation for porketta, all the better. If it's not sporting a net to hold it together, move on. It needs a net and must be covered in spices from all angles, and two pounds is about the minimum size. I did this last night with a four-pounder, and five people vaporized it in under an hour.
Break out the slow cooker, and grab these ingredients:
Put about 1/4 can of cream of chicken soup in the bottom of the slow cooker. Pour in just enough chicken broth to cover about about 1/4" of the bottom of the slow cooker. Fire it up on high long enough to dissolve the cream of chicken soup. Once that's dissolved, set the roast in the slow cooker, pour in the remains of the can of chicken broth and switch the slow cooker to low. Now, take the other 3/4 can of cream of chicken soup and spoon it onto the top of the roast, spreading it evenly around every surface not sunken in broth.
Let it sit on low for about 8 hours, then cut off and remove the net and break it up with a fork until it's sandwich-style meat. Any clumps of spice stuck to the net should be forked out, broken up, and put back into the mix. Stir it well to dissolve them into the solution.
Pour off the excess liquid, approximately half, but it'll look like the meat's no longer a soup.
Turn the cooker to "warm", or the lowest setting, for a couple more hours.
Slice the buns, and serve warm. Experience Porkgasm.
I made this for my crew today, and 3 out of 5 called it the "best porketta" (or pork, period, in 2 cases) they'd ever had. I did better a couple of weeks ago because I used a better roast; time and travel constraints kept me from getting one from my normal supplier, so I'm one of the 2 dissenters (I ate the whole previous 4lb roast myself over a weekend), and my driver is not given to any kind of extremes... but she added she would use my recipe from now on.
Variation: add a slice of onion, thickness dependent on your tolerance of onion, and some good Italian red sauce. Around these parts, this variance (though not on the above recipe) is known as a Santini Special... and, as a side note, if your red sauce is available nationally, it's garbage. Either make your own, or find a moustachioed old Italian woman that sells it out of her basement like drugs. Good stuff!
If I can find my recipe for red sauce, I'll post it.
- A porketta roast (duh).
- 1 can cream of chicken soup (do not manually masturbate the chicken; it's not the same--Campbell's has it figured out)
- 1 can of chicken broth
- A bunch of good, home-baked rolls from the local bakery.
